I need to know how to access screen display from the monitor menu
SOURCE: HP w2007 monitor will not turn on.
The only troubleshooting step I can offer here, is unplug it, and press the power button down for about 15-20 seconds, to flush any trickle power remaining in the unit. Then plug it back in, hook it up and try turning it on again. If this solves it, great! If it doesn't though, then I would check either with HP directly or with your place of purchase to see if your issue can be covered under limited/extended warranty. If you are out of warranty though, LCD repairs tend to jump pretty high, and usually end up being more than what the monitor is worth, so it may be more economical to replace it at that stage.
SOURCE: HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
SOURCE: hp w2007 monitor: Powers on but screen is white -
This is an internal problem with the LCD monitor. It is defective and should be returned to the store your purchased it from for a new one. That is the only thing I can really think of if it is not reading properly with a seperate graphics card. It is an internal issue and needs to be repaired.
SOURCE: my hp w2007 monitor keeps
I'VE BEEN HAVING THE SAME PROBLEM FOR MONTHS - SOMETIMES THE MONITOR WILL BE FINE FOR A FEW DAYS AND OTHERS IT WILL NOT COME BACK ON NO MATTER WHAT I DO. HOWEVER, I FINALLY FIGURED OUT THE PROBLEM AND THUS A SOLUTION AND IT ACTUALLY DIDN'T COST ME ANYTHING.
MY CPU DOES NOT HAVE A VGA OUTPUT SO I WAS GOING TO GO BUY A VGA/DVI CABLE ADAPTER BUT INSTEAD I FOUND A VGA/DVI ADAPTER IN THE BOX THAT MY COMPUTER CAME IN. I ATTACHED IT TO THE DVI CABLE THAT I ALREADY HAVE AND PLUGGED THE DVI END INTO MY CPU (SINCE IT ONLY HAS A DVI AND NO VGA OUTPUT) AND THEN THE VGA ADAPTER END INTO MY MONITOR AND WA LA... IT WORKS NOW AND HAVEN'T HAD ANY PROBLEMS WITH IT GOING TO SLEEP.
WHAT I IMAGINE IS HAPPENING IS THAT THE DVI OUTPUT ON THE MONITOR IS FAULTY - EITHER FROM THE FACTORY OR THE PINS HAVE BEEN DAMAGED SO MY CABLE WAS NOT WORKING CORRECTLY. IN TRYING TO FIGURE OUT WHAT WAS WRONG, I BOUGHT A BRAND NEW DVI CABLE AND IT STILL DIDN'T WORK SO I KNEW IT WAS NOT THE CABLE. THAT NEW CABLE WAS RETURNED TO THE STORE FOR A REFUND!
SOURCE: hp w2007 lcd monitor, osd lockout & main menu display
Once you realize that resetting it doesn't work (as I did ) take it apart. This instruction is for an hp w2007 only! It's the one I just fixed. Remove the three screws holding the base on. The one in the middle is hard to see because it's in a hole but readily accessible. Remove the black back cover by inserting a skinny screwdriver between it and the gray housing. Start in the middle on any of the four corners.Pry it up and work your way to the corners. At the corners pry up with more force and the plastic tabs will snap off. Trust me, just do it!! Once you have snapped the plastic tab at all four corners the back will lift right off. locate the three small wires that go into the menu, -, +, select switches. Cut the three wires and tape them off separately. Do this so they can't touch the case or each other. Do to the wires that are going back toward the monitor! The ones going to the switch do not need to be taped. The switches are now dead. Is that clear? Cut the wires going to the switch and tape the cut ends that go back to the monitor. You will no longer be able to manually adjust anything but I never used the adjustments anyhow. The PC will take care of it for you. I did this 8 hours ago and it's still working perfect! Before I made the fix I was getting OSD Lockout, no input signal, it was scrolling through the menu and the screen was going blank every 5 minutes!! It will work!!!
