Touch pad not working
Did it work for you before? what has happened since then?some laptops have a way to disable the touch pad so you won't accidentally move the cursor while typing. It may be a switch on the computer itself, or a LED in the corner of the touch pad, or it may be one of the Function keys (does any of them have a symbol of a mouse with a circle and one diagonal line indicating "no mouse") If so, push the fn key plus which ever function key has that symbol beside it.Some laptops automatically disable the touch pad if a USB mouse is plugged in.If none of these is the problem, you may not have a touch pad driver installed. Get a USB mouse to plus in until you get the driver installed. Go to the web page for the manufacturer for the laptop. Search for your model in the support section, and look for drivers. Download the appropriate driver for your touch pad and your version of Windows, and install it.Buying a USB mouse or a wireless mouse may be a valid solution no matter what the problem is if you like a real mouse.
