Washing Machines Logo
A
Anonymous Posted on Mar 10, 2015
I have replaced the carbon brushes in my logixx 8 machine after error code F43 appeared .the machine works ok but the washing stays soaking wet on the wash programmes
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Mar 16, 2015
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567467
Points
3788
Make sure the pump wires have not got accidently dislodged when changing the brushes. Also check the program cycles, you may have accidently selected a "no spin" cycle.
SIEMENS WM12S740EE/11 Washing Machine. HOW DO I RESET SIEMENS WASHING MACHINE?
This error can't be reset, it is a repair job. The code mostly means that the carbon brushes are end of life. You can replace them yourselves with new spare parts.
Mar 22, 2018
Please don't type all in capitals. It is hard to read and considered 'SHOUTING'.
https://www.google.com/search?q=siemens+WM12S740EE%2F11+error+f43
1helpful
Logixx8 Bosch washing machine displays F43, detergent and softener drawers were emptied, but clothing not washed, half is wet, the rest dry. What do I do?
Motor carbon brushes burned out and needs to be replaced. You can YouTube the procedure and do it yourself or call a service center and tell them you know precisely was wrong with it and how much to replace the parts and labor. It's a. 45-60 job
good luck
1helpful
2answers
Errore f43
Check motor connector block
Check motor carbon brushes
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check wiring
Check tacho connections
Check motor
2helpful
F43. Terminal?
motor brushes on bosch machines typically last 6-7 years its the first thing to check
2answers
F43
Hi.
If you have Bosch, Baumatic, or any other machine built by Bosch, then F43 is a motor issue:
Error F43 : Motor fault: do an emergency drain through the drain access in the front bottom side (see manual). Open door and check ig the drum rotates free when spin by hand. Disconnect power before performing maintenance.
Regards.
Ginko
2answers
My new bosch logixx front loader washing machine (3 weeks old) is showing a flashing error code F:43....what does this mean ? Thanks
I just realised that I don't appear to have a comprehensive list of Bosch error codes, but some quick research tells me that F43 is a motor error, usually associated with the motor brushes requiring replacement (Though they may also be sticking and just require removing, cleaning and re-fitting).
2helpful
Hello can you please help me.. i have a big problem with my washing machine error on F43 Bosch logixx sensitive can you send me what the problem is.. Rune from norway
For Bosch Logixx, F42, F43 and F44 all decode as 'motor fault indicated'. Sorry ;-0)
I changed the motor on our Bosch (not a Logixx) at a cost of GBP250! I do expect it to last another 20 years, though.
If this has assisted you please score accordingly.
Thanks and good luck!
John C
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
