SOURCE: my upstairs toilet burps air when flushed all other toilets ok
Your vent stack may be clogged. The pipe that goes up to the roof. Let's air into sewer pipes when you flush. A birds nest or something can do it.
SOURCE: toilet flushes fine but when
The ball float follows the tank water level, and repeated cycles of the float dropping and opening the fill valve would likely reflect a leak in the flush valve. You could try adjusting the float arm downward so that it will respond to a lower water level. Try turning off the supply valve, flushing it and listen for water leaking past the flush valve after it closes. If it does, replace the flapper or adjust the chain.
SOURCE: Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
