the web began to take over some of the functions of teletext from the late 1990s, and many broadcasters have ceased broadcast of teletext-CNN in 2006 and the BBC in 2012. The decline of teletext has been hastened by the introduction of digital television, though an aspect of teletext continues in closed caption .
you should press the home button of your teletext page usually its 100
or you could press one of the four colored buttons o your remote control unit so it will reset to the home page of the teletext
(a black page mostly says that teletext isn't available to the specific channel )
Hello
Check it from the cable operator/service provider, are they offering text service if so, then consult with user manual or technician for assistance.
good luck
The teletext board in that set is an add on and as such if it is taken out the set will work happily without it and as teletext no longer exists in the UK, not a problem. When the set is switched on without the panel, the microprocessor will see there is no board because it won't get the hand shake and perform as though it were a 42WH08B Hope that helps.
A factory reset made teletext available again on digital channels.
When on standby, push on remote in quick succession <info><menu><mute><power> buttons. Follow onscreen menu to option 12 (reset) and select. Be aware that you will have to tune in all analogue and digital channels again.
