Dell Inspiron 6000 Notebook Logo
Valeria Rossi Posted on Mar 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do I need a proxy setting? - Dell Inspiron 6000 Notebook
KiranK
Level 2:
Sergeant:
  • Dell Expert 352 Answers
  • Posted on Mar 12, 2015
KiranK
Dell Expert
Level 2:
Sergeant:
Answers
352
Questions
0
Helped
47715
Points
886
Hi Valeria Rossi,
Let me know what exactly are you trying to do or when is the proxy being prompted. Depending upon your answer I can check and help you further.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Proxy settings
Why do you need proxy settings? You only need proxy settings if you are using your Laptop at work or at Uni where there is a proxy server installed. Its normally in Internet explorer, Tools, Internet options and connection...
tip
Gprs & MMs settings for india mobile networks 2
&gt;IDEA GPRS SETTING <span> </span> <span> </span>#Account Name - Idea GPRS <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Homepage - http://wap.ideafresh.com <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Proxy and Server adress - 10.4.42.45 <br /> <span> </span>#Databearer - GPRS / Packetdata <br /> <span> </span>#Acces Point Name - imis <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Authentication Type - Normal<span> </span> <br /> <span> </span>&gt;IDEA MMS SETTING <br /> <br /> <span> </span>#Connection name - IDEA_MMS <br /> <span> </span>#Databearer - GPRS <br /> <span> </span>#APN - mmsc <br /> <span> </span>#User name - <br /> <span> </span>#Prompt password - No <br /> <span> </span>#Password - <br /> <span> </span>#Authentication - http://10.4.42.21:8002 <br /> <span> </span>#Proxy serv. address - 10.4.42.15:8080 <br /> <span> </span>#Proxy and server Port - 8080 <br /> <span> </span>&gt;VODAFONE GPRS SETTING <br /> <span> </span>#Account Name: Vodafone_gprs <br /> <span> </span>#Homepage: http://live.vodafone.in <br /> <span> </span>#User Name: <br /> <span> </span>#Pass: <br /> <span> </span>#Access Point Settings: <br /> <span> </span>#Proxy: Enabled <br /> <span> </span>#Proxy Address: 10.10.1.100 <br /> <span> </span>#Proxy Port: 9401 <br /> <span> </span>#Data Bearer: Packet Data <br /> <span> </span>#Bearer Settings: <br /> <span> </span>#Packet Data Access Point: portalnmms <br /> <span> </span>#Network type: IPV4 <br /> <span> </span>#Authentication: normal <br /> <span> </span>#User Name: <br /> <span> </span>#Password: <br /> <span> </span>&gt;VODAFONE MMS SETTING <br /> <span> </span>#AccountName:- vodafone <br /> <span> </span>#Server:- http://live.vodafone.com <br /> <span> </span>#Proxy:- 196.006.128.012 <br /> <span> </span>#Proxy Port:- 8080 <br /> &gt;BSNL GPRS SETTING <br /> <span> </span>BSNL PORTAL <br /> <span> </span>#Account Name - Bsnl Portal <br /> <span> </span>#Username - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Acces Point Name - celloneportal <br /> <span> </span>#Homepage - wap.cellone.in <br /> <span> </span>#Proxy and Server Adress - 192.168.081.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Data Bearer - GPRS / Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <span> </span>BSNL NORTH <br /> <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://petercrys.com <br /> <span> </span>#Proxy and Server address - 192.168.051.163 <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name (postpaid) - www.n.po <br /> <span> </span>#Acces Point Name (prepaid) - www.n.pr <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br /> <span> </span>BSNL SOUTH <br /> <span> </span>#Account Name - BSNL GPRS <br /> <span> </span>#User Name - Your mobile no <br /> <span> </span>#Password - <br /> <span> </span>#Proxy - Enabled/yes <br /> <span> </span>#Homepage - http://localhost/home.wml <br /> <span> </span>#Proxy and Server address - **** <br /> <span> </span>#Proxy and Server Port - 8080 <br /> <span> </span>#Acces Point Name - bsnlsouth <br /> <span> </span>#Data bearer - GPRS/ Packetdata <br /> <span> </span>#Authentication Type - Normal <br /> <br />
on Jan 11, 2011 • Cell Phones
20helpful
7helpful
Proxy setting 130
Exactly error: "Unable to connect to the proxy server
A proxy server is a server that acts as an intermediary between your computer and other servers. Right now, your system is configured to use a proxy, but Google Chrome can't connect to it.
Here are some suggestions:
If you use a proxy server, check your proxy settings or check with your network administrator to make sure the proxy server is working.
If you don't believe you should be using a proxy server, try the following steps: Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed."
Any doubts you can get the help of a technician through
www.thebestpcdoctor.com
Toll free: 877 407 9229
How to setup proxy server
To set up your system to use a proxy server, right-click Internet Explorer, click "Properties." Click the "Connections" tab and click the LAN settings button (near the bottom). Click the check box under the proxy server setting and input your information. If you need a list of IP proxy servers, try http://www.hidemyass.com
3helpful
Whose nokia 2690 net connect
Take any multimedia and set
Hutch GPRS Settings
* 1. Account Name - Hutch_GPRS
* 2. User Name - Blank
* 3. Password - Blank
* 4. Proxy - Enabled/yes
* 5. Access Point Name - portalnmms
* 6. Full Internet Access Point Name - www
* 7. Proxy and Server address - 10.10.1.100
* 8. Proxy and Server Port - 8080
* 9. Homepage - http://hutchworld.co.in
* 10. Authentication Type - Normal
Airtel GPRS Settings
* 1. Homepage - any page you want to set.
* 4. Proxy - Enabled/yes.
* 5. Proxy and Server Adress - 202.56.231.117
* 6. Proxy and Server Port - 8080
* 7. Data bearer - GPRS or Packet Data.
* 8. Access Point Name - airtelgprs.com
* 9. Authentication Type - Normal
* 10. Use preferred access point - No
Airtel live settings
* 1. Account Name - Airtel_live
* 2. Homepage - http://live.airtelworld.com
* 3. Username - Blank
* 4. Password - Blank
* 5. Proxy - Enabled/yes
* 6. Proxy and Server Adress - 100.1.200.99
* 7. Accespoint Name - airtelfun.com
* 9. Data bearer - GPRS/ Packet Data
Idea GPRS Settings
* 1. Account Name - idea_GPRS
* 2. Username - Blank
* 4. Homepage - http://wap.ideafresh.com
* 5. Proxy and Server Port - 8080
* 6. Proxy and Server adress - 10.4.42.45
* 7. Databearer - GPRS / Packetdata
* 8. Acces Point Name - imis
* 9. Proxy - Enabled/yes
BSNL GPRS Settings
* 1. Account Name - BSNL WAP
* 2. Username -
* 3. Password -
* 5. Homepage - http://wap.mizone.bplmobile.com
* 6. Proxy and Server address - 10.0.0.10
* 7. Proxy and Server Port - 8080
* 8. Acces Point Name - mizone
* 9. Data bearer - GPRS/ Packetdata
I have a w760i mobile phone and i need internet setting for it.my mobile operater is airtel.please help
official procedure
1.for mobile office setting send mo to 543210
2.for nop setting send nop to 543210
3.for airtel live setting send airtel live to 543210
for activaition of gprs plan dial *567#
manual setting for airtel live
Manual Settings for Airtel live
3. Username - Blank
4. Password - Blank
manual setting for mobile office
Manual Settings for Airtel Gprs
3. Password - Blank
4. Proxy - no proxy.
5. Proxy and Server Adress - 0.0.0.0
12helpful
2answers
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error.
Try this,
Go in control panel>internet properties->connections->lan settings->proxy server and uncheck use proxy server for your 'lan setting'
Hope it helps.
Bolck of myspace from shcool computers
You need to go through a proxy server. Proxy settings can be changed in the Tools, internet options, connections tab. bottom right LAN settings. Check use a proxy at the bottom. Input the proxy server IP address and the port number. Unfortunately I cannot suggest any proxy sites but do a google for "free proxy server" you will find a list of available proxies.
Im sure your school blocks those types of sites so you will need a list of the IP addresses and port numbers before going to school :)
I hope this helps!
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
