Just Wireless Bluetooth Headset Wireless Headset Logo
A
Anonymous Posted on Mar 10, 2015
I can't get the headset to pair with my blackberry phone
How can i pair the headset with my w58oi
Dennis Prather
Level 2:
New Friend:
  • Expert 99 Answers
  • Posted on Mar 10, 2015
Dennis Prather
Expert
Level 2:
New Friend:
Answers
99
Questions
0
Helped
20606
Points
302
Turn off the phone and set the bluetooth on the phone, with it on, then turn the phone on it should pair up. if not got to your Bluetooth settings and enter the numbers that the headset has in the instructions. usually 0000 works.
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
2answers
I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
Hi,Instructions on how to pair blue tooth device with black berry.
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Have a nice day .
2answers
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Tips & Warnings
Hope it helped.
Thanks for usingf ixya..
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 • Cell Phones
15helpful
Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
H500 Headset Problem
This is the same headset I have.
I believe you have to hold the power button in until the light starts to blink, then tell your phone to look for the device. Don't forget to remove the device in your blackberry if you are still using it.
Top Just Wireless Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
