It's simple to change the time on a Fanmis sport pedometer. To get to the "Time" setting, all you have to do is keep pressing the "Mode" button. Then, after pressing the "Set" button, change the time using the "Start/Stop" and "Reset" buttons.
Once the time has been set, you may resume recording your steps and working toward your fitness objectives. After all, if you want to keep healthy, time is of the essence!
According to Casio, in the time keeping mode hold the E until each of the following steps occur. hold SET appears in digital display>HT flashes. Second hand points to the current home city code. Set 2: Use A to select the city code you want to select as your home city. Each press of A moves the second hand clockwise. keep pressing A until it lands on the city code you need. Select your home city code before changing any other setting. Step 3: Press D to cycle through the available settings on the digital display. When the time keeping setting you want to change is displayed, you A ad or C to change it. Step 5: Press E to exit the screen, the hands of the watch will move to the time you set. Any other information or diagram is listed on the website Casiowatchparts.com
Most timers for irrigation are easy just take the control knob and put it on the timers face for example it will say set- time to set the time, next it will it will say date ,water times and days there will be a --- or a + sign this will make it go forward or backwards for example to set time push + button and it will start at 12:00am keep going until you reach desired time once you get time click knob to next assignment and it will set automatic repeat and go to each assignment than put knob on auto make sure you have back up batteries in case electric goes out it will keep timer set.
This model phone will not keep time. You can reset it, re-register it or WHATEVER. Next time the phone rings, it loses track of time again and has to be re-set.
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
