Question about Korg Music
Korg pa50 I have a korg pa 50. The problem with my keyboard is that after few seconds of playing the keyboard starts giving a heavy distorted windy noise. For few tones the distortion is less or nill. But every other tone n rhythm has this distortion problem. The distorted sound gets normal in between but comes back again. I checked with the earphone output also but still the same. I doubt it is an issue with the amplifier or the ocilllators. What do you suggest.
    Top Expert:
  • Korg Master
  • 3,156 Answers
For aproblem of this nature, I would suggest contacting Korg directly. Here is a link to their contact page. Contact KORG
Posted on Mar 10, 2015
  • benjamin john Mar 14, 2015
    I found the real problem with my pa50. Somewhere a component is getting heatedup. It is now functioning properly in a chilled air conditioned space with the keyboard body partly open. so now it is not getting heated up. But now I have to find which part is getting heated.
SOURCE:
  • 1140 Answers
SOURCE: when I play the sound come out distorted, like it
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Posted on Aug 20, 2009
  • 5603 Answers
SOURCE: korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Posted on Feb 01, 2010
  • 5603 Answers
SOURCE: Hi Iam using my
The styles on the PSR9000 are NOT available on the PA50. Any styles of the PSR9000 would only come from the audio generation and outputs of the PSR9000. The PSR9000 would have to be setup to the style independently as that cannot be controlled via MIDI from the PA50 controls.
Posted on Jun 25, 2011
cosmin_bcr
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
Posted on Oct 06, 2011
SOURCE: korg pa50 freezes at start up and only says "KORG PA50"
I think it is time for you to buy one new one....That you can but on side for parts.
Posted on Apr 04, 2012
Problem with Korg PA-50 joystick in Program mode
Most likely the Program Mode does not copy joystick info.
Get the User Manual online, if you want Google
KORG PA50 FACTORY RESET
But then you will lose all your memories...
Dec 02, 2017 | Korg Music
How to reset pa 50
The manual should the factory re-initialization procedure. If not contact Korg customer support
Dec 10, 2014 | Korg Pa50 Professional Arranger Keyboard...
Halo my name is budi..i am an indonesian korg pa50 user ..my pa 50 was blank and only rised on display "ssd not present"..what should i do??
Hi
I work with computers rather than musical instruments, but I imagine with all the things keyboards do these days they are almost certainly computerised, and your saying "tried to install os" confirms this.
In computers "SSD" stands for "Solid State Drive". If there is an SSD in the PA50, then it is quite clear to me that it is no longer working properly and needs to be replaced. Confirmed by the fact that you can't install the OS.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 20, 2014 | Korg Music
Kord pa 50 enciende, pero no funciona
ola claudio
tienes que resetear el organo y despues cargar el os
Dec 13, 2013 | Korg Pa50 Professional Arranger Keyboard...
Some keys on the left side are not giving sound when played and the master volume is loosing can it be fixed or should i have to buy a new master volume
It's about hardwares.
Wiring connection sockets is loose.
Inside the korg PA50,Wiring connection to the keyboard is separate to left and right.
Open/disassemble your korg.
Look for connection cable to the left keyboard.
One end is on the keyboard,the other end is at the mainboard.
Unplug both of it, then mounted again.
For master volume,better buy new one.
Jul 31, 2013 | Korg Pa50 Professional Arranger Keyboard...
Bulk dump to another pa50sd
*** fac o resetare generala la pa 50 sd
May 27, 2012 | Korg Pa50 Professional Arranger Keyboard...
Korg pa50 freezes at start up and only says "KORG PA50"
Apr 04, 2012 | Korg Pa50 Professional Arranger Keyboard...
FACTORY RESET ON KORG pa50SD
i use korgpa50sd i had some voices by default but once when i inserted my sd card into the arranger every voices got deleted and now everything is new...so can you please help me to get back the old voices?
Apr 02, 2012 | Korg Pa50 Professional Arranger Keyboard...
Hi Iam using my korg pa50 as the master keyboard ive connected the midi cables to my other keyboard which is a yamaha psr9000 I cannot play the chords on the pa50 using the styles on the psr9000 is there...
Jun 25, 2011 | Korg Pa50 Professional Arranger Keyboard...
Music Logo
201 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Poul Brinchs Larsen
tmaree
tmaree
Are you a Korg Music Expert? Answer questions, earn points and help others
