Open Default Programs Editor. Select "File Type Settings" and then "Context Menu". Use the search bar to find your extension, select it, and press Next. Select the Open command and click "Edit Selected Command..." http://electronicshelponline.blogspot.com/
Using Microsoft Word for drawing is not recommended. If you are interested in a simple drawing program, use Paint instead. There are also many -free- advanced drawing programs such as GIMP which may suit your needs better.
If those files weren't premarked properly on computer before synchronizating (you can do that in WMP 10 with advanced tag editor) it's not likely you'll get those results. You can add those info on computer and sync files again. However, if all of these files are marked properly (have filled Artist, Title and Album sections in advanced tag editor) maybe database is corrupted - what you need to do is refresh it. (Settings>Extra>DataBase Refresh>Yes)
Use registry cleaner like cCleaber, uniblue registry editor or Advanced System Optimizer and configure it to lave only essential programs to start-up, optimize system performance, set menu delay and ability to skip non-essential programs on Start-up. I personally use Advanced System Optimizer for the past 3-4 years and it has worked wonders....sodeep
The "circular reference" indicates that the xref you are pulling in is also xrefing the drawing file you are in which creates this circular reference to each other. The error message is only a warning and does not prevent you from working and saving changes. To get rid of the error message, close the primary drawing file and then open the reference drawing and DETACH the xref that is linked to your primary drawing. Save the changes and then open the primary drawing file again to see if the error was resolved.
it save in the printshop folder. look under the porgram file on your c drive.
do a file save in pirntshop, it will tell you where the file being saved. and also that is where you can change where you wan tthe file to be saved.
