Expert
- Posted on Mar 10, 2015
Re: How do I delete a recording off my Sony Sony -...
- Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status.
The stop mode window appears.
- Select the file you want to erase when the IC recorder is in the stop or playback mode.
- Erase a selected file.
When the IC recorder is in the stop mode, press and hold ERASE.
When the IC recorder is in the playback mode, press ERASE.
- Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
- To cancel erasing, How do I delete a recording off my Sony Sony - ICD - souni_stop.png="/uploads/images/souni_stop.png" alt="souni_stop.png" class="h_mi" />(stop) in step 3.
- To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
