I have the Samsung model: LN46E550F6FXZA, I can hear it power on, the red light on the front blinks 5 times then goes off. There is no sound or picture.
Tony, need some info for help like model number, age of set, can u unplug for 10 min. then turn back on, and since u have taken back off what have u tested or looked at?
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Any malfunction associated with a flashing light usually indicates a
circuit problem or defective component. Unfortunately, the days of
taking off the back cover of your TV and replacing a defective tube or
fuse are long gone. Proper servicing will require troubleshooting
procedures that can only be performed by a qualified electronic repair
facility or professional television repair person. Ask for an estimate
and a realistic appraisal of whether the set can be adequately fixed.
Depending on the age and condition of your TV it may not be cost
effective to repair.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is. no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
You really should give make & model number when posting, it helps us immensely, your lamp and possibly the ballast is bad, start with a new lamp first, odds are very good that it will fix your problem, can`t help more without manufacturer and model number, good luck, ps, order the original lamp, generics are junk and a waste of your money.
