Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- i heard 3 beep sounds from speaker with out DDR RAM installed and with RAM installed there is no display and no beep sound. CORE VOLTAGE 1.4, RAM -2.5, CLOCK -3.3, AND OTHER VOLTAGES ON BOARD ARE QUITE OK.. Pls. tell me how can i slove my problem.
  • 2 more comments
  • mnjpnd Nov 14, 2007
    i did the same. but no display at all. the problem is remain same.
    pls. give some other tips so i can slove my display problem.
  • Anonymous Mar 03, 2008
    MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display , no beep sound & no booting Bios, ( SMBS, RAM ,, PROCESSER, & HD Are all ok). Pls. tell me how can i slove my problem?
  • samy6522 Jun 06, 2008
    yes
  • Anonymous Jan 11, 2009
    my ram is ok no falt in mother board volatge is ok you why display is not come
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Posted on Mar 01, 2008
  • Anonymous Mar 01, 2008
No display in my motherboard P-945 and all component is ok
Posted on Sep 05, 2008
My mother board has taken the problen lite on but no display
Posted on Jun 03, 2008
Posted on Apr 03, 2008
My problem is dispaly plz solf
Posted on Mar 05, 2008
  • 490 Answers
Please disconnect all the device attached like HDD,FDD,CDROM/DVD , means attach only MB to supply and try to switch it on , it will help you solving the problem , once the display gets back then point by point you can attch the devices back
Posted on Nov 13, 2007
SOURCE:
I am install xp sp2 on intel pantium 4, ddr1 ram(256mb), intel mother board & lost sound & display drivers so help for download these driver
Go to IBM's official website. Click on free drivers download. Select your model and operating system. Download drivers and install in your PC.
Aug 03, 2010 | IBM Netvista Intel Pentium 4 2.4GHz /...
No display on mother boards
Are these computers all emachines? this board is normally used in the emachine range of computers and have a problem with the architecture Call me ? chris http://www.motherboardsrus.net 07926-106150
Jun 05, 2009 | Intel D845GVSR Motherboard
No display on computer
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
No display in a board
hello
the beep is due to ram
try to remove ram and insert again while power is off
Nov 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
No display
hi
if you known about your all SMBS, RAM ,, PROCESSER, & HD Are all ok
  1. chack your ram then clean your ram slot
  2. smps ok
  3. about me your screen is black
  4. chang your bios battery 1st
  5. you use any video card...
Mar 03, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
552 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
