Question about Mercedes S-class S500
How do remove the lower under dash panel to replace the blower motor in mercedes s500 2004 ?
Where are the screws connecting the panel to the dash?
    Top Expert:
  • Mercedes-Benz Master
  • 6,815 Answers
Hello
u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
Posted on Jan 29, 2019
SOURCE:
  • 84 Answers
SOURCE: How do I replace the heater blower motor on a 1989 190e
Hello, The blower motor is located below the windshield wiper assembly. You have to remove the plastic cover that below the windshield then remove the wiper assembly, then you will see the blower housing. Remove the screws from the housing then remove housing cover. Look close because some of the screws are hard to see. Once you get the cover off, you will see the motor and there is a metal strap that holds it down. Take a punch or whatever and stick it in hole in the strap and push down. Then the motor will come out.
I hope this helps.
CYA, Gator241
Posted on Feb 06, 2009
  • 27 Answers
SOURCE: how to remove the Dash instrument panel in a 1990
Use a wide flat spatula in the lower left under the actual cluster. There are two clips in the back of the actual cluster.
Posted on May 22, 2009
paulrogersco
  • 21 Answers
SOURCE: where is the 1995 mercedes-benz s320 blower motor located.
The blower motor is on the passanger side lift the bonet and there is a long black plastic cover the same lenth as the wind screen, remove that and you will see it, a new motor is like £1000 from Merc but you can buy a copy motor off ebay for less than £50 thats what I done. It is the com that wears out on the motor not the bushes, strange I know
Posted on Jul 10, 2009
lastech
  • 408 Answers
SOURCE: blower motor works only on high on 1995 mercedes e320
hello,good day,first try to check your blower switch,if not corrected,your blower resistor is located at the bottom of your brake booster,ty
Posted on Jul 25, 2009
Shorty1_wt
  • 324 Answers
SOURCE: Mercedes blower motor.
check the blower fuse? check for voltage at the switch (requires removing heater / ac controls from dash on most vehicles.)
Posted on Apr 22, 2010
How do I replace heater blower motor on e320 benz
First remove passenger side under dash panel. should be about 4 or 5 #20 torx head screws to dropo the blower out of the system.
Mar 02, 2015 | Mercedes-Benz E320 Cars & Trucks
Mercedes slk200 blower motor removal
Remove the passenger side, lower dash cover under the glove compartment that conceals the blower motor. A 1/4-inch socket will be needed to remove the screws holding the cover. Locate the blower motor. The motor can be seen hanging down close to the passenger kick panel, disconnect the electric to the blower motor and then remove the screws that secure it to the ducting, drop blower down and out from under the dash. I would test the blower first with a 12 volt jumper cord from the battery made out of house lamp cord, it is not usually the problem but the blower speed control module that is next to it.
Sep 10, 2012 | 2000 Mercedes-Benz SLK
I need to replace a blower motor on a 1998 GMC Sierra 2500 6.5L diesel. Could you tell me how to go about it, how much of the dash do I have to remove? Thanks
To Remove:
  1. Disconnect the negative battery cable.
  2. Remove the glove compartment from the instrument panel.
  3. Remove the front screw from the right door sill plate.
  4. Remove the right kick panel trim.
  5. Disconnect the electrical connectors from the powertrain control module (PCM), as needed. Remove the PCM and mounting bracket if equipped with a diesel engine.
  6. Disconnect the electrical connector from the blower motor.
  7. Remove the bolt from the right lower instrument panel support.
  8. Remove the blower motor cover.
  9. Remove the blower motor cooling tube.
  10. Remove the blower motor mounting flange screws.
  11. Carefully pull the blower motor forward in order to avoid distorting the fan and pry back on the right side of the instrument panel to as necessary to remove the blower motor.
To Install:
  1. Guide the blower motor assembly into position. Avoid catching the blower fan on any protruding parts.
  2. Install the blower motor mounting screws.
  3. Install the blower motor cooling tube and blower motor cover.
  4. Install the bolt in the right lower instrument panel support.
  5. Connect the electrical connectors, as necessary.
  6. Install the mounting bracket and the powertrain control module (PCM) if removed.
  7. Connect the electrical connectors to the PCM, as necessary.
  8. Install the right kick panel trim.
  9. Install the screw into the front door sill plate.
  10. Install the glove box in the instrument panel.
  11. Connect the negative battery cable.
  12. Check the operation of the blower motor.
Feb 03, 2011 | GMC Sierra 2500 Cars & Trucks
Blower motor sounds like it is going to stop. how hard is it to replace?
here are the instructions for fan blower removal. remove lower right dash insulator panel from under glove box. slide the body control module aside for access to the blower motor.( bcm ). remove the 3 screws that hold it in. pull the blower motor and fan straight down and dis connect electrical connector. if replacing blower motor, remove fan to put on new motor. 99 olds cutlass, have a good day !! just take your time and it is not that hard.
Jan 22, 2011 | 1999 Oldsmobile Cutlass
I cant find the blower motor
If you mean the climate control blower motor, it's usually under the dash on the passenger side on Hondas.
1990-93 Accord
  1. Disconnect the negative battery cable. If so equipped, disable the Supplemental Restraint System (SRS).
  2. Remove the glove box.
  3. Remove the glove box frame (lower support) Fig. 2: Remove the glove box and frame 86806004.gif
  4. If not equipped with air conditioning:
    1. Remove the three screws and remove the heater duct.
    2. Remove the blower mounting nuts. Unplug the wiring from the blower motor, resistor and recirculation control motor, then remove the blower assembly.
  5. If equipped with air conditioning:
    1. Lift the carpet in the passenger compartment. Remove the side cover (kick panel).
    2. Remove the control unit bracket nuts; unplug the five connectors and remove the control unit bracket.
    3. Remove the retaining band, then remove the blower lower covers. Do not break the tabs on the lower covers.
    4. Remove the retaining nuts and remove the blower assembly. Fig. 3: Air conditioned models require the removal of the control unit. Handle it carefully 86806005.gif
      Fig. 4: Remove the lower covers from the blower unit 86806006.gif
      To install:
  6. Install the blower unit and tighten the retaining nuts.
  7. On air conditioned vehicles:
    1. Install the lower covers and the retaining band.
    2. Install the control unit bracket and carefully engage the wiring connectors to their proper location.
    3. Install the kick panel and reposition the carpet.
  8. Connect the wiring to the blower assembly. For non-air conditioned vehicles, install the air duct and tighten the screws.
  9. Install the glove box frame and install the glove box. Note that some of trim on the frame is held with 2-sided tape; replace the tape when reassembling as necessary.
  10. If applicable, enable the SRS.
1988-91 Prelude
  2. Remove the glove box and frame (lower support).
  3. Remove the 4 screws and remove the heater duct. Fig. 5: The glove box and frame are secured by several small screws 86806007.gif
  4. Remove the 3 mounting bolts.
  5. Unplug the wiring connectors from the blower motor, resistor and recirculation controller. Remove the blower motor assembly.
  6. Reinstall in reverse order. Make certain the blower mating surfaces are tightly sealed.
Jan 08, 2011 | 1992 Honda Accord
How do I replace the heating fan on my 2000 Kia sportage
Blower Motor
Removal & Installation
To Remove:
  1. Evacuate and recover air conditioning refrigerant.
  2. Remove battery.
  3. Disconnect and cap A/C lines at evaporator tubes.
  4. Remove blower motor assembly drain.
  5. Remove glove box.
  6. Remove 5 screws and right hand instrument panel lower trim panel.
  7. Remove screw that attaches upper center console to gain access to left
    instrument panel lower support.
  8. Remove left and right bolt and remove instrument panel lower support.
  9. Detach control cable from inlet duct.
  10. Disconnect blower motor electrical connector.
  11. Pull carpet back and remove hole cover plate.
  12. Remove 2 bolts at top of blower motor assembly.
  13. Remove 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  14. Remove blower motor assembly.
To Install:
  1. Install blower motor assembly.
  2. Install 2 bolts at top of blower motor assembly.
  3. Install 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  4. Install hole cover plate and replace carpet.
  5. Connect blower motor electrical connector.
  6. Install instrument panel lower support and install left and right bolts.
  7. Install right hand instrument panel lower trim panel and 5 screws.
  8. Install glove box.
  9. Install blower motor assembly drain hose.
  10. Connect evaporator lines at bulkhead.
  11. Evacuate and charge air conditioning refrigerant.
  12. Install battery.
Oct 29, 2010 | 2000 Kia Sportage
If I need to replace the blower motor for my 2001 Ford Expedition air conditioner, does the entire dash have to be removed to reach it?
If you are removing the main blower motor at the passenger side of the cabin then you don't have to remove the dash. It's behind the lower dash trim panel and takes about an hour and a half to two hours to do. Not to bad a job but you will need to be a bit flexible to see under there.
Jun 08, 2010 | 2001 Ford Expedition
How to remove the blower motor from a 1978 ford bronco full size truck?
Deluxe Hi-Lo Heater
  1. Disconnect the battery cable, remove the carburetor air cleaner and partially drain the coolant system.
  2. Remove the heater hoses from the heater core.
  3. Remove the glove box liner and remove the register duct by pulling from the instrument panel register and releasing the clip at the plenum.
  4. Disconnect the right cowl outside air inlet vacuum hose from the outside/recirculating door vacuum motor.
  5. Remove the rear housing from under the instrument panel. Remove the outside air inlet duct from the rear housing (4 nuts and 1 bolt) and install one upper nut to retain heater housing-to-dash after rear housing is removed.
  6. Remove two screws retaining plenum-to-dash (above transmission tunnel) and two screws to heater housing and remove the plenum.
  7. Install a piece of protective tape on A-pillar inner cowl panel, at lower right corner of instrument panel.
  8. Remove the lower right instrument panel-to-A-pillar bolt to hold the panel in the rearward position.
  9. Remove the heater core (3 screws retaining 2 plates).
  10. Remove the temperature blend door (snaps off).
  11. Remove the temperature blend door arm support (2 screws) and pivot arm retainer (1 screw).
  12. Remove blower motor (2 screws) and remove blower wheel.
To install:
  1. Transfer blower to blower motor and panel assembly.
  2. Install door arm pivot retainer (1 screw) and door arm support (2 screws).
  3. Install the temperature blend door (snaps on).
  4. Install heater core.
  5. Install the plenum (4 screws).
  6. Connect blower wires.
  7. Remove heater housing upper retaining nut and install the heater outlet (4 nuts and 1 bolt). Position the air inlet duct.
  8. Connect the white vacuum hose to the outside/recirculating door vacuum motor.
  9. Reposition the instrument panel, install the retaining bolts and remove the protective tape at the A-pillar inner cowl panel, lower right corner of instrument panel.
  10. Install the right register duct assembly and install the glove box liner.
  11. Connect heater hoses to the heater core assembly.
  12. Fill cooling system, install the air cleaner and connect the battery cable to the battery.
  13. Check blower motor operation.
Jan 19, 2010 | 1981 Ford Bronco
How do i replace the heater blower motor
Remove the glove box.Then remove the glove box lower frame.The blower motor will be on the
right hand side under the dash.Remove three 10 mm screws.After removing the screws pull the
blower motor forward and up.There will be three harnesses connected in the lower right side
of the blower.
Nov 06, 2009 | 1992 Honda Accord
Where is fan blower motor located on 99 toyota camry
The blower motor for the inside of the car is located on the passenger side of the dash under the glove box. Should have a lower panel under the dash to remove. Remove the panel and you will see the blower motor mounted under it.
Sep 14, 2009 | 1999 Toyota Camry
Mercedes S-class S500 Logo
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
