Camera says card has wrong format. Press ok to format.....camera says card is locked. Unlock card ....then goes back to card has wrong format and so on and on
Download any pics from the card using a card reader if necessary. Then, insert the card into the camera. Go into the menu and find "format"...follow the on-screen instructions.
ok ...see that into the side of the card( if its a SD) has a slide like button with 2 positions ...one of them is the unlocked one ...after that either format it into the camera if it has that feature...or just connect it to the computer and it will be found somewhere into the My computer as a removable drive ....just right click and format in Fat 32...this is the actual storage format fit for this cards..
No, it won't work unless HP provides a firmware update. Hp has two websites that mention what type of sd cards are compatible with your camera. One says it is and the other says it isn't. I have a HP R967, which is similar to yours. I bought an HP sdhc card from a HP website that said both our cameras could use it. I own several of this model camera, (I bought 3 to give as gifts) and the sdhc causes the cameras to display 'wrong format.' I suggest calling HP's headquarters and asking them to provide a firmware update similar to the one that HP offered for the HP M537 camera and that Casio offered for their older cameras to let them use this type card, which is what I've been doing.
I have an HP R927 and just had the same problem. Take out your memory card. Look on the side of the card and you will see and white "knobby thing" ... make sure it is pushed up ... that should fix it.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
if we are talking about an sd card, on the opposite side to the 'cut' corner is a small piece that slides away from the contacts to lock, slide this away from where it says lock if this is the case, but make sure it wasn't protected to save something important before use, This may have caught on something as you slid the card in, and it's only tiny!
