Televison & Video Logo
A
Anonymous Posted on Mar 09, 2015
Put a tv onto av mode without using the remote?
Frederick Electrick
Level 3:
Master:
  • Master 350 Answers
  • Posted on Mar 09, 2015
Frederick Electrick
Master
Level 3:
Master:
Answers
350
Questions
Helped
107273
Points
1344
Some older tv's you need the remote to switch the input mode,
most tv's your can simply go threw the chanel up and down and av Will be in between channels? Hope this helps?
How to set AV mode on my BPL Prima 18CC1 TV without remote.
Without a remote control, you can't select its inputs. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
I want to watch a cctv camera on my tv but can't put tv into av without remote to watch
Please try using a univerrsal remote as the AV is switched only externally by this way. The other option is to short the AV switching transistor from the output of the processor but for this you must identify the pin and do it with care not to tamper the circuit.
This can make the AV to be ON and so help you with the cam.
1helpful
Tips to operate without remote
You might try hitting the MENU button on the tv itself to see if you are able to select input / source that way. Some TVs also have the Aux Inputs selected by scrolling through the channels until you come to the aux inputs.
6helpful
2answers
INPUT MODE WITHOUT REMOTE
Hi
If you cannot reach the AV input mode by scrolling through the channel up down, nor is there is a source or TV/AV button on the set it self, then the news is bad I am sorry. You will need the remote to get AV inputs on this set.
You can get a new remote for the set from here for $1995. Plus postage. Note that it has the TV/AV button.
Happy to answer any questions you may have.
regards robotek
How do I record onto a DVD from a video camera
connect camera to dvd on the dvd were you connected into will have (e.g EXT or AV 1-2 or 3 printed on it) you should put dvd on to that input mode by pressing input/saurce on remote then put tv on the input mode you watch dvd on
to record press on remote
3helpful
2answers
Changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
2answers
Av mode?
well if you change the channel to the highest it goes some TV can be changed to a/v mode
or the lowerest number under 2 sometime a/v might be there
remote stop working due to batteries or drop remote, might have to be replaced either abtteries or whole remote.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Change av without remote
get a universal remote if i wer you it may solve it but they do cost a bit ... look on the bright side you can tune those to any tv in the world =)
3answers
Tv is in AV mode
you would need to purchace a universal control you can find these in shop like currys ask the teqs there or look on ebay for a remote like your old one
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
