Video Game Consoles & Games Logo
A
Anonymous Posted on Mar 09, 2015
Not compatible with windows8.1 watt do I do???
Trevor Campbell
Level 2:
Scholar:
New Friend:
  • Expert 115 Answers
  • Posted on Mar 09, 2015
Trevor Campbell
Expert
Level 2:
Scholar:
New Friend:
Answers
115
Questions
0
Helped
15891
Points
249
You can try Vuze (http://www.vuze.com/) it will act as a server and your PS3 will recognise it. Once installed drag any movies,music etc into Vuze under the PS3 option and your PS3 will pick up all media within Vuze. Obviously you can then stream them to your console.
2answers
Does genesis model number G-608 digital series are they Bluetooth compatible?
According to Specifications IT IS NOT BLUETOOTH compatible. Please see spec:
Specifications:
2000 Watts total system power
5.1 AV Receiver
500 Watts Sub
1500 Watts Stellite and center
10" Long Throw Active Driver
Digital Audio Video Input, Digital Output
Digital AM/FM LCD Display
2 Blue Power Watt Meters
Pure Piano Black Lacquer Finish
Plug and Play IPod, MP3, DVD, CD, HD-TV compatible
Bass, Treble, Full Function Remote Control
IS BOSE ACOUSTIMASS 5 SERIES II COMPATIBLE TO DRIVE WITH YAMAHA AV RECEIVER RX-V379
Hello Richard, if your Bose Acoutimass 5 Series II, are compatible with your Yamaha RX-V379, using them in the L and R Front outputs of the Yamaha, this set is prepared to work between 10 to 200 watts of power, your Yamaha delivers 70 watts per channel, what is within the range of work of the Bose
I am sending you the link so you can download the Bose guide
I hope you enjoy the Yamaha-Bose convention
Greetings Franco Dosil
Hola Richard, si tus Bose Acoutimass 5 Series II, son compatibles con tu Yamaha RX-V379, usandolos en las salidasL y R Front del Yamaha, este conjunto esta preparado para funcionar entre 10 a 200 watts de potencia , tu Yamaha entrega 70 watts por canal, lo que esta dentro del rango de trabajo de los Bose
Te estoy enviando el link para que puedas descargar la guia de los Bose
Espero que disfrutes de la convinacion Yamaha-Bose
Saludos Franco Dosil
https://www.bose.es/es_es/support/products/2_speaker_home_theater_support/am5_series2.html#SupportTabs_tab0
Are subfoofer ts-w308d2 and amplifier GM-5300T compatible with each other?
Yes. You will be able to run this setup with the sub bridged across both channels of the amp, which will give you more power (which the sub will be able to handle: 380 watts rms), or with the sub wired to a single channel, which will give you less power (125 watts rms). The sub can handle 400 watts rms.
My 1HP160 watt desktop psu went bad. Should I replace it with the same thing or is there something else in a higher wattage that is compatible?
Yes most PSU's are standard fittings. Certianly with HP. 160 watt is a very low spec look at 350 watt at least. Cheap enough to replace.
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Will the garmin edge 705 provide/ be able to produce a power watt measure during outdoor rides and what do i need to purchase to be able to get this information?
The 705 comes in multiple versions from basic that will give you heart rate to a team garmin version that has the cadence, speed, calories, etc. As for power meters the 705 is 3rd party compatible to show you watt measurements.
The following third-party ANT+Sport-enabled power meters are compatible with the Edge 705:
  • iBike
  • PowerTap
  • Quark
  • SRM
2answers
Peak and tune a mini magnum 30 10 meter radio
You need schematics and a good peak reading watt meter. You can do damage if you don't have eqipment/knowledge.
Compatability
Any programmable UHF 450-470MHz mobile radio could be programmed to the frequencies of the Spirit MU series radios.
Your radios are 2 watts, so you would probably want to stay with a 1-10 watt, or 10-25 watt mobile radio, to have the best success. The current compatible model for Motorola is the CM200 UHF radio. If you are looking at a used radio, just simply watch for it to be UHF 450-470 MHz.
Then when you are ready to have the mobile radio programmed, the dealer (or programmer) will need to know the settings of your MU radios. These are easily read out over the phone, or in person by an experienced programmer.
I have a GE Profile ModelJVM187OSK04 Serial # DM902972B The bulbs went out, they are 120 volt 20 watt. Can I use a GE 120 25 watt bulb as I am having trouble finding a 20 watt??
You should be able to use the 25 watt bulb as long as they are compatible with the socket they mount in... Hope that helps...
Blaupunkt MP74 compatible CD Changers
Specifications
Amplifier
Output power: 4 x 18 watts sine
at 14.4 V and 1%
distortion factor at
4 ohms.
4 x 26 watts sine
in accordance
with DIN 45324
at 14.4 V at 4
ohms.
4 x 50 watts max.
power
Tuner
Wavebands:
FM : 87.5 - 108 MHz
MW : 531 – 1 602 kHz
LW : 153 – 279 kHz
FM frequency response:
20 - 16,000 Hz
CD
Frequency response:
15 - 20,000 Hz
Pre-amp out
4 channels: 4 V / < 1 kω
AUX input
Input sensitivity: 1.2 V / 10 kω
Above are specs for the LA mp74 digiceiver
This is where I found the pdf information for cdc ao71 changer, only problem is it is in other languages.
http://fe0wap79.bosch.de/is-bin/INTERSHOP.enfinity/eCS/Store/en/-/EUR/BeAT_ServiceDocuments-Start;sid=xMwY5KjfON3gIuDbMbhKGKdU-8dWMZg3sZ0=?Language=FR&search_query_name=cdcao71&SellerId=CM_DE
I will keep looking.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
