Tablets & eReaders Logo
B
Betty Hinton Posted on Mar 09, 2015
I want this billed to my amazon account and delivered to another address
JRBK
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Mar 09, 2015
JRBK
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1285
Points
11
When you put an item in your basket and then go to check out it will ask you what credit card you want to use. Then it will ask you what shipping address you want to use. You will have to input the new address I hope this helped
3answers
I can't register my Amazon Fire HD8
To buy content and deliver it to your device, you will need to connect to a wireless network and register your Fire tablet to an Amazon account.
If you are setting up a new Fire tablet for the first time, you'll be taken through setup instructions and will have the chance to register your device. Follow the instructions on your screen.
To register your Fire tablet outside of the initial setup screens:
  1. From Home, swipe down from the top of the screen and then tap Settings.
  2. Tap My Account.
  3. Tap Register.
    • If you already have an Amazon account: Enter your Amazon account information, and then tap Continue.
    • If you do not have an Amazon account: Tap Start Here, and then follow the instructions to set up a new account.
Note: If you've forgotten your Amazon account password, you can reset it by requesting that a personalized "password reset" link be sent to your e-mail address. To learn more, go to Reset Your Account Password .
If you need to deregister your device from an Amazon account, follow the steps above, and then tap Deregister. After you deregister your device from an Amazon account, you won't be able to access items stored in the Cloud for that account.
After deregistering, you can register your Fire tablet to another Amazon account. Related Help Topics
How can Iget my fire registered
To buy content and deliver it to your device, you'll need to connect to a wireless network and register your Fire tablet to an Amazon account. Registering also allows you to transfer purchases between devices and Kindle reading apps. To learn more about connecting to a wireless network, go to Connect Wirelessly.
  2. Tap My Account.
  3. Tap Register.
    • If you already have an Amazon account: Enter your Amazon account information, and then tap Register.
    • If you do not have an Amazon account: Tap Create Account, and then follow the instructions to set up a new account.
How do I get it from content manager to home so I can read it?
On the Amazon website, to get to the content manager:
  • Log in to Amazon
  • In the upper menu, find "Your Account" and hover to expand the menu
  • Click on "Manage Your Content and Devices"
  • Find the document you want to send to a device
  • Click on the "..." button to the left of the listed document to open the menu
  • Select "Deliver"
  • A dialog displays "Deliver Titles"
  • Select the device you want the document on, and click "Deliver"
Good luck.
What is my amazon account
If you don't know what your amazon account is, you may not have one yet.
If you do have an existing Amazon account, the user name is likely to be an email address (at least at present). You can try entering your email address and possible passwords, or go through the procedure of resetting your password.
Good luck.
2answers
Having trouble adding kindle generation 5 to my kindle fire account
Amazon is cautioning clients of more seasoned Kindle tablets that they In the event that the issue continues, if you don't mind restart your Kindle from the Menu in Settings and attempt once more. Arouse fifth Generation. Encourage Touch fourth Generation. Encourage Paperwhite fifth Generation. First gander at Amazon's Fire tablets For more help related kindle devices contact our kindle customer services number +1-844-769-9823.
2answers
How do I regidster my new kindel fire h6
To register your new kindle you need to go to http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Akindle%20registration and follow the directions.
Register Your Kindle Register your Kindle to your Amazon account to buy and deliver Kindle content to your device.
To buy and deliver Kindle content, you'll need to connect wirelessly and register your Kindle to an Amazon account. Registering also allows you to transfer purchases between Kindle devices and Kindle reading apps.
  1. From Home, press the Menu button, and then select Settings. Select Registration.
  2. Specify the Amazon account you want to use for your Kindle:
    • If you already have an Amazon account: Select this option. Enter the e-mail and password associated with your Amazon account. Select Register. Your name will appear as the Registered User when registration is complete.
    • If you do not have an Amazon account: Select this option and follow the on-screen instructions to set up a new Amazon account.
Having trouble?
2answers
How do I receive my kindle books when my email address is different?
I assume you mean kindle books you order online (not from the kindle itself?)
They are delivered to your Kindle based on what you have registered on line, not to your email. Therefore changing your email address should not matter (at least directly).
When you say 'moved' - do you mean moved house physically (which does not matter at all) or moved to using a new kindle? Assuming you mean a new kindle, you need to
A) make sure the kindle is registered to your Amazon account: go to home screen, touch top of screen to bring up menu and then press the 'three lines button', select settings. There should be option to register (you will need email address and password - so you need to make sure your online Amazon account has correct email address registered! This is where email change might be causing problems, but can be updated online)
B) when you order books online you need to select the correct kindle to deliver to in the drop down box next to the order button (it might be called something like "Paul's Second kindle")
You can access all books you have ever bought (for this kindle or any other) on Kindle paper white by selecting 'cloud' when on the list of books at home screen.
Hope that helps, if not please reply and explain in more detail what you are doing and what happens / does not happen
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
