Dell Studio One 19  PC Desktop Logo
A
Anonymous Posted on Mar 08, 2015
How do i adjust the brightness on a dell studio?
Martin ODonnell
Level 1:
Habit-Forming:
New Friend:
  • Contributor 19 Answers
  • Posted on Mar 10, 2015
Martin ODonnell
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
19
Questions
0
Helped
38160
Points
87
Load the latest video driver from Intel and it fixed the problem.
Here is a link to the driver that you need:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=2991&DwnldID=18336&lang=eng
2answers
How to reduce brightness of dell vostro 1015
Saddam Al-Nasser wants more answers to this question
Let me guess it is too bright in a dark room?
dell vostro 1015
NO OS stated, at all. by OP or Hyjackers.
the dell site has xp vista and w7 driver only for this old PC
if the device manager shows, keyboard drivers missing then try the one below marked,
Mouse, Keyboard & Input Devices 07 Jul 2012
below covers both types of personal computers.
http://www.pcdied.com/sleep-or-dim.html
and you cant find the 2 key below>?
https://www.dell.com/support/home/us/en/04/product-support/product/vostro-1015/manuals
oops dell lost the users manual after 9 long years, sadly
see the 2 keys below, blue, sun Icons
you push Fn blue key left side of keyboard
then push SUN key down. lower red arrow below.
if this fails to lower the backlamps
that means the drivers are missing. xp,.vista,w7 are all dell supports. (NO OS stated by OP nor hyjackers. as is par here)
Fn+down-arrow : key. if dead driver is wrong.!!!
kbd-baidec2mt3oofykszl5jzacu-2-0.jpghttps://www.dell.com/support/home/us/en/04/product-support/product/vostro-1015/drivers
2answers
I working on my sister Dell Studio laptop. Her son got a hold of it and pressed the power button several times while pressing several buttons. Now the laptop does not boot correctly. I power it up and the...
Remove battery and AC power, press power button for 30 seconds. reconnect ac power and try again.
Also check the hot keys (brightness) usually Fn and F6, see if that help
1helpful
2answers
How to adjust the brightness in pinnacle studio
Hi and Welcome,
To adjust the brightness in Pinnacle Studio all you have to do is to click on Toolbox>add Video Effects. Standard RTFX then auto color correction.s
Regards,
Since yesterday, the picture on my laptop has been distorted and I can't figure it out. Looks like the contrast is off. Can't find how to adjust it and I tried to calibrate without any luck. I turned it...
Hi. Restart your system and press F2 key when you see the Dell Screen. You can adjust the Screen brightness or contrast from there. See if that'll help!!!
^_^
My C610 Dell has a screen that is a little darker than it should be. Would this likely be the backlight or inverter. Should both be replaced at the same time as a matter of standard procedure? T R
Have you tried adjusting first the brightness level? If nothing happens when adjusting it, the LCD and LCD cable needs to be replaced. If im not mistaken, i believe there is no backlight/inverter that can be replaced since its already built in the LCD. Some Dell laptops have inverters like Studio 1737 that can be replaced. Hope this helps
Brightness remains dimm ever after laptop is on AC Supply
are you using xp vista or windows 7
xp might be the screen saver settings. vista or windows 7 check power options in search
1helpful
2answers
Screen is dark at start up
If its running on batteries the screen brightness will dim quite a bit. If on AC adapter it should be full brightness, but this is adjustable in either case. With the computer up and running, press and hold down the Fn key and push the up arrow to make it brighter and the down arrow to make it dimer.
2answers
How do I adjust brightness on Dell E152FP monitor
there's a buttong located on your monitor. just look for it then set up brightness to watever display u want.
1helpful
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
7helpful
2answers
Unable to adjust the brightness of display screen
bright ness buttons are indicted witha sun like mark . they r usaly used with fn keys look for that keys
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
