Hotpoint Aquarius WMA42 Front Load Washer Logo
A
Anonymous Posted on Mar 08, 2015
Not going through programme properly - Hotpoint Aquarius WMA42 Front Load Washer
paul
Level 3:
  • Master 825 Answers
  • Posted on Mar 10, 2015
paul
Master
Level 3:
Answers
825
Questions
0
Helped
174089
Points
2202
Check pump for a blockage....
cheers
Candy as108
IT has shorted out u will need to replace board
tip
Air Conditioning Programmable Thermostats - Great for Heating and Cooling
Programmable thermostats contribute to overall system performance, maximizing energy savings while providing complete comfort control. They also allow flexibility to homeowners because they can be programmed to match their lifestyle. Programmable thermostats save energy by turning down the cooling and heating system at night or at times when your home is typically unoccupied.
Did you know that properly using a programmable thermostat in your home is one of the easiest ways you can save energy, money. Homeowners can save about $180 a year by properly setting their programmable thermostats and maintaining those settings. They can achieve significant energy and money savings that are possible through the proper use of your programmable thermostat. Programmable thermostats do two things:
(1) Compare the thermometer reading of a room's temperature to the "ideal" thermostat temperature you select.
(2) Give start-and-stop commands to the heating or cooling system in order to achieve an indoor temperature that is as close to your "ideal" thermostat setting as possible.
Your savings will largely depend on the length of your energy saving program periods and the temperatures set. For example, an energy saving period of 10 hours with the temperature set back 10° will save more than a 5 hour energy saving period with the temperature set back 5°. By maintaining the highest or lowest required temperatures for four or five hours a day instead of 24 hours, a programmable thermostat can pay for itself in energy saved within four years.
A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home. The precise temperature control of a programmable, energy-saving thermostat saves wear and tear on high-efficiency heating and cooling equipment by properly cycling the equipment. A programmable thermostat will keep you and your home comfortable while you are there to enjoy it, and will change the set point at programmed times to an energy savings level when you are not home.
Controlling your heating more effectively could save you up to 17% on your heating costs. In fact, during the winter you can save about 3 percent of your heating costs for every degree you lower your thermostat. Begin lowering your heating bill immediately with the pre-programmed 7-day schedule, or modify the programming to suit your lifestyle. By delivering the heating or cooling when you need it, and optimizing temperature for activity, sleep and times you are away you can maximize your comfort level and save energy.
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3916016-honeywell_th8320u_thermostat
http://www.fixya.com/support/r3913560-honeywell_th8110u1003
http://www.fixya.com/support/r3902153-honeywell_rth7500d_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
on Dec 06, 2009 • Heating & Cooling
1helpful
Need to programme my remote to a lg blueray player
Your owners manual for the remote should supply you with both the operation and the proper codes. If no manual go to support on the remotes website and download an operators manual.
murf427
I have an Acer Extensa 4420-5963 laptop. It was working properly. To free some space in C drive I uninstalled some programmes. After thAT I am facing 2 problems:- (1) 4 way Scroll Button (situatted...
Then you have uninstalled the wrong programmes (they wouldn't take up that much space anyway) Go to the Acer site and download the software for your lappy and reinstall.
Recording and actually WATCHING the programmes I record
this feature its not from the TV is for DVR box, that storage the information on a hard drive inside, check your DVR model and number and google the proper manual for it
When i click on any programs open with comes up
it is normal it is happening because the programme u wants to run it is asking that with with what application it will run. there are mainly 2 reasons behind it either u dont have the proper application downloaded in ur computer which supports that perticular programme or u have more than 1 application which supports that programme.thats why computer is asking with which application u want to open the programme
Somebody while working in my p.c has removed the sound system in the year 2006 april.
First of all u go to start- programme- accessories-system tools then click on system restore , system restore in back date when ur computer sound was working fine . After that if ur sound is not coming then go to controll pannel then add/remove programme , remove the sound driver and then restart the pc , after restarting the pc then reinstall the sound driver properly then after install the driver check
2answers
Cannot get lifecam vx1000 to work with person.com when you start the cam it comes on then after a couple of seconds it says webcam not connected or in use by another programme what programmes could be...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 Go to this site and sign-in. http://person.com/webcams.personals_search.phtml then go to webcam and click on it and setup you camera so it will operate on person.com. All webcams have to be setup to operate on a program so it will operate properly.
Hope this helps. Bud
4helpful
Classixx 6 1200 bosch washer...I've set the washer to a programme regularly used but an indicator light 'a Key' symbol flashes above the time indicator and the programme will not start . Door is closed...
It is the childproof lock that has been set, to clear it you need to set machine as you would normally to start a programme but hold the START/PAUSE button for 5 seconds, that will clear it, remember that is also the way to put the lock on again so I would advise not holding the start button down too long.
Top Hotpoint Washing Machines Experts
vince
Paul Carew
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
