Microsoft Windows XP Professional SP3 Full Version OEM for PC  Logo
Anonymous Posted on Jul 09, 2009
My pc wont load into windows, blue screen says image kernel32 checksum
Anonymous
Level 2:
  • Expert 71 Answers
  • Posted on Jul 09, 2009
Anonymous
Expert
Level 2:
Answers
71
Questions
0
Helped
29191
Points
208
this problem could be fixed with the recovery console:
- insert the Windows XP installation cd and boot from it. - Select "Recovery Console" when prompt - type the following command:
Bootcfg/rebuild
The second (longer) option is to recover you XP installation
cheers
Stop c0000221 bad image checksum image
Try loading in Safe Mode and disabling as many Startup programs is MSCofig as possible. You could also try rolling back with System Restore, again in Safe Mode. From there try uninstalling any software that was loaded prior to the problem.
Another route is trying to load Windows on top of its self as to correct any corrupted files. Then try testing your RAM one DIMM at a time, one slot at a time to eliminate bad RAM.
Finally a clean install may be required, then going back to RAM isolation if occurs with a clean Windows setup.
1helpful
My laptop wont load to Windows XP when it tries to I get the following message. STOP:c0000221 {Bad Image Checksum} The image shell32.dll is possibly corrucpt. The header checksum does not match the...
Just FORMAT it... But if you scare of losing your info and data, then choose the option to REPAIR the windows installation. Or what you can do is do a checkpoint system restore. You will have to go through much more headachs to resolve it.
Most of the time that problem occurred because of an unsuccessful installation of a program or app. Or you might of deleted a common file accidently...
your windows is surely corrupted.. install your windows again... if you dont know how to install your windows...contact me....at ([email protected])
please vote for me...im sure this will solve your problem...
Dell laptop won't boot even after clean install of xp
your windows prolly crashed because your hard drive is going bad, and thats why your getting error messages when reinstalling.
Blue Screen
Try re-starting your pc and tapping the F8 while it starts up and try getting in through "Safe Mode". If you can get in click "Start", "Run" and type "cmd". Hit OK. At the dos promt type "sfc" and let windows check your files.
1helpful
Error - Kernel32.dll
Microsoft defines Kernel32 errors as follows: "The Kernel32.dll file is a 32-bit dynamic link library file that is found in Windows 95, Windows 98, or Windows Millenium Edition (Me). The Kernel32.dll file handles memory management, input/output operations, and interrupts. When you start Windows, Kernel32.dll is loaded into a protected memory space so that other programs do not take over that memory space. On occasion, you may receive an invalid page fault (IPF) error message. This error message occurs when a program tries to access the Kernel32.dll protected memory space. Occasionally, the error message is caused by one particular program, and other times the error message is provoked by multiple files and programs." .
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
