Checked hose checked tecdrive im told to check sreen is in place don't know were to look
Screen is on the tank, sometimes it gets pulled of with the hose, look inside hose.
Start with the hose OFF the tank (make sure small filter is in place).Fill the tank with water and KIRBY DRY SHAMPOO (other shampoo's wont foam) then turn the vacuum on. At this time the shampoo will come out as a stream of foam. If the shampoo come's out as liquid then you will need to check the tank. If shampoo was left in the tank ,then the pick-up hose inside the tank my be colgged. These are hard to un-clogg so replacement of the tank may be needed.
Here's my online guide for using the Kirby shampooer....
HOPE IT HELPS!!
Marci
