Download manual
connect your phone to a computer,download your pics onto your sd card,now your phone storage should be cleared out,and your pics will be on your sd card,what i do,is i send my pics to myself and open and download them on my phone and to the sd card
SOURCE: Can't set ringtones that are in my memory card as ringtones!
well if u have internet on your phone you could try buying ONE ringtone and one that ringtone is installed a new folder will come into existance. i think its caled my contestant of something. Anyways, try connecting ure phone to your pc and from then on, all songs u downlaod should become a ringtone if put into that folder. Just a guess though. try it
SOURCE: f698 flying dual sim phone showing ''invalid sim''
Your phone is a Dual Band, it only works with 900/1800mhz. Make sure that the Sim install in the second Sim slot work for these bands here. Other wise it won't work. Another problem could be the imei number, most of the time it can be resolve by changing the imei number for the second Sim slot, but is kind of hard.
SOURCE: I have a dual sim YPhone I68 and don't know how to
I just figured this out myself...on your pc go to getjar.com. When it asks you what phone you have type in CECT and select the default phone. when you find the app you want select download n it'll give you a code. Go to services on your phone and select WAP. go to m.getjar.com. under platforms select JAVA. Scroll to the bottom of the screen and select quick download. input the code you got from the computers webpage and click download....then just follow the prompts. when you want to access what you downloaded go to JAVA in your phone. select Installed Java Software and it should be listed. (Note: this only works if you've set up internet on your phone.)
SOURCE: Need a proper user manual/set-up
http://www.fileguru.com/apps/sciphone_i9_3g_manual
Above is the link for your manual.
Below are some good i9 sites.
http://www.i9-cell-phones.com/
Look below at the master Google link for the i9 3G
http://www.google.co.nz/search?num=100&hl=en&rlz=1C1CHME_enNZ370NZ370&q=website+sciphone++i9+3g&aq=f&aqi=&aql=&oq=&gs_rfai=
SOURCE: Karbon moblile ohone Dual sim setting is not
Copy the flashfile with the new mobile in spiderman and download to that mobile
