There is either a small 'c' clip on the front/bottom side or it has an iternal snap ring. If it is the 'c' clip you should see a small slot that you can pop the clip out. If it has the internal one, it pulls straight up and off. Warning: Do not twist it, you will break something expensive in the shifter. From the service manual....
Detaching the shift control knob from the shift lever may require a large amount of physical effort.
Do not twist the shift control knob while pulling.
Firmly grasp the shift control knob.
Pull straight up to detach from the shift lever.
Installation Procedure
Align the shift control knob to the shift lever.
Firmly press down on the shift control knob in order to attach to the shift lever. An audible sound will be heard when the internal clip is fully seated.
Here's a video too!...
How to Remove shift Knob Cadillac Seville
