Question about Lexicon Alpha Personal Recording Studio
Lexicon alpha interface is recording a faint high pitched sound
My lexicon alpha is recording a faint high pitched sound with my voice over recordings. I was wondering what is going. The tech at lexicon told me that that was a design flaw with the older models, but I just bought mine.
how can I fix this?
and most importantly... Are my recordings now compromised?
can my recordings be fixed?
Kris W
  • Lexicon Master
  • 5,603 Answers
Check for ground loops.
You MIGHT be able to cut the noise by setting the EQ's to clip the highs.
Posted on Aug 24, 2009
SOURCE:
Lexicon alpha and gxl2200 microphone
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
Mar 05, 2013 | Lexicon Alpha Personal Recording Studio
There is a high frequency noise in my sessions. I am using a Lexicon Alpha interface with Cubase 5 but now I can't record because of the noise. How can I solve this problem?
Make sure you are using BALANCED cables either XLR or TRS. Make sure ALL interconnected equipment is powered from the same receptacle. Make sure the level to the Lexicon is line level as using excessive gain at its input will admit noise.
Jul 28, 2011 | Lexicon Alpha Personal Recording Studio
I have Lexicon alpha, Condenser Mic, phantom power .If i record, the voice goes only to right speaker. I am using cubase le 4, stereo in/out are correctly.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Feb 12, 2011 | Lexicon Alpha Personal Recording Studio
Just bought a lexicon alpha. I installed everything, all drivers are up to date. I can get it to play audio out through my monitors but I can't get it to receive signals in. I tired my sampler into the...
First, I could NOT find an MXL99 microphone... IF you have an MXL990 microphone, you can STOP trying to have the Alpha read it because it won't !!! The MXL990 is a condenser mic and requires that Phantom power be supplied to it and the Alpha does NOT have Phantom power.
I have found a common problem on the audio interface inout is having to GO INTO the windows Sounds and Devices and verifying that under the VOICE tab, checking that the inout device is listed AND then checking the volume is turned up in that window... It seems like you have to verify everything and tweek a dozen places to get everything right to work. Having to look under the "VOICE" tab is not a good description of where the Alpha input control should be... so anyway, check that as well as it is not MUTED in that window. With Adobe Audition, make sure you set under the options, the "metering" to monitor the input recording level.
Jan 15, 2011 | Lexicon Alpha Personal Recording Studio
I have bought a Lexicon alpha and have a consenser mic. Since the alpa doesn't support condenser mics I am running the mic through the system I bought it with, a ART TUB MP. Still I cannot get any...
You should be using XLR to XLR cable from the ART to the Alpha. You need to have recording software and the driver for the Alpha correctely loaded. Verify that in the PC when you go to the control panel in Windows and click on the "Sounds and Devices Icon that clicking on the VOICE tab that the Alpha is listed as the default audio for both in and out.
Dec 27, 2010 | Lexicon Alpha Personal Recording Studio
Hi, i have the Lexicon Alpha Personal Recording Studio connected to my mac via USB. im running two powered speakers via phono to phone lead. When i try play music through the speakers it doesnt play...
Make sure you have NO antivirus/antispyware/antiadware or other resource hogging background programs running while processing the audio. These programs hog resources to the point that the buffering within the audio devices is overrun causing gaps.
Nov 22, 2010 | Lexicon Alpha Personal Recording Studio
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
Lexicon Alpha got phantom?
The Lexicon Alpha does NOT have phantom power. The mic input expects a standard mic or a "self-powered" condensor mic. This means that you will neex external phantom power. There are power units available that use 9V batteries for this.
Dan
Sep 09, 2010 | Lexicon Alpha Personal Recording Studio
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
Open Questions:
Lexicon Alpha Personal Recording Studio Logo
845 people viewed this question
Top Lexicon Music Experts
Michial Gueffroy
Gil Shultz
tmaree
tmaree
Are you a Lexicon Music Expert? Answer questions, earn points and help others
