Engine is fine, cable is tight and engaging / disengaging ok. I would expect the blade to spin faster with more resistance when engaged and not sure what is wrong.
Your deck belt need tighten
The spindle shaft could be broken. If this is a multi blade machine, it would only be one blade since it is unlikely you broke them all. Belt tension or routing of the belt would be the first thing to check, especially if you had the belt or deck off prior to this. I accidentally routed a belt wrong. That will wear them out fast.
I forgot to mention to check a broken spindle, with engine off, engage blade (I am assuming a mechanical belt tensioner, and not electrical clutch) try to rotate the blade. If it rotates easily, the spindle is broke or the spindle drive pulley is not engaged on the spindle. Could have broken a key or worn spines.
Check condition and tension on belt. When engaged it should not depress more than an inch. Check wear on pulleys. Clean under deck - blades, bearings, pulleys, etc.
