Where do I buy a lightbulb for the Nostalgia model?
I just need a lightbulb. I was told this one "E27 40 Watt" light bulb is used. I entered that on Amazon and a huge assortment of different bulbs came up. I don't know which one.
Question edited for full 'make model (what it is)'.
Question moved from Cars and Trucks category.
You will need a multimeter to check the switch and cabling to the socket, and also check if the new bulb is good.
REPLACING THE BULB
1. Use only a 10 watt maximum, candelabra base bulb.
Turn the light switch off and unplug the saw.
2. Remove old bulb. Place new bulb into socket
depending on model which is not disclosed, older ones have a light socket just inside under the top cabinet edge. The are protected from damage, so use a mirror to look in that area. It is normally a 25 watt, SES cap Appliance Bulb.
In more moderm fridges, LED lighting has taken over. The whole unit has to be replaced because they are supposed to last 20 years. Some have LED strips at the door edge.
On page 4 of the pdf it indicates that an E27 40 Watt light bulb is used.
You should be able to purchase a replacement bulb in any lighting department that stocks a full range of light bulbs including appliance bulbs; this would more commonly be referred to as an oven light bulb.
Check the tab in the center of he bulb socket. Unplug the frig first and gently pull it up a little. You should be using a 40 watt appliance bulb not a 60. If the tab is not the problem you may need a new switch. Eric
no, i have the same light...i just inserted the 2 pronged lightbulb in the middle of the metal plate where there should be a small socket with 2 holes...you have to be carefull with these kinda bulbs...they are easily damaged, prongs being broke from being put in and out...too frequently and ect.
