HP DeskJet 940c InkJet Printer Logo
A
Anonymous Posted on Mar 08, 2015
Why does HP Deskjet 940c only print left side of a selection from a web page?
Michael C
Level 2:
Novelist:
  • Expert 176 Answers
  • Posted on Mar 08, 2015
 Michael C
Expert
Level 2:
Novelist:
Answers
176
Questions
Helped
51783
Points
501
A printer prints almost anything that is shown in a computer screen and it depend on what you're trying to print. If you want to print contents from a webpage, you have two options to chose from. The first is of course the contents in the webpage that you want printed and the second option is to print the whole webpage. If you want to print only the contents in a web page, e.g. an article or photo, you have to highlight the article or photo first then right-click and select 'Print...'. It should print the article or photo only. But if you want to print the whole webpage, chances are that it only prints the 'skeleton' of the webpage and not the contents, hence the reason you have only the left part of the webpage printed. However, if you highlight the whole webpage and then right-click and select 'Print...' I am sure you will have the whole webpage printed. Cheers.
Need to make adds or flyers . iwant to print same add 4 times on same page.
Under printer properties, printing preferences, finishing there is a tab that says "pages per sheet". Select 4 and print!!!
My HP deskjet 940c has been out of use for a while and I just started using it again. It now prints like have of a page, stops and continues the rest on another piece of paper. Why and how do I fix it?
put a single paper at a time when u give a printing command. also use good quality papers. Adjust the size of the tray.
i hope this would resolve the problem
2helpful
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
I just purchasea a new internet provider called Frontier I was formally with AOL dial-up. My problem is when printing emails on Frontier, a dark gray background appears, the text is reduced in size and I'm...
Not familiar with Frontier...most email programs has a "print view" option...if not try highlighting by click & drag across what you want to print, click file at top left,print, selection,ok
1helpful
940c just prints only half the page it starts printing without the first part of page
try replacing the print cartridge. If that doesn,t work try cleaning the ink reservoir. Be careful it could get messy. use a q-tip with a little alcohol. also clean the contacts behind the print cartridge. always turn off the printer before servicing it.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
Hp deskjet 940c printer
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
k24674
Grand Canyon Tech
Grand Canyon Tech
