I appreciate your inquiry, friend!
I see that you are having an issue with your digital clock shutting off on your Frigidaire range. This could be a potential short within you wiring harness or control panel. I would recommend performing a reset on your range and you can do that by disconnecting power from your range for roughly ten minutes. If that does not correct your issue you may need to have an electrical component replaced and that is not a simple DIY job. I would suggest having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
