Precisely the above, there are 9/5 C degrees for each F degree. Don't forget the 32 degrees F at which water freezes because it freezes at 0 degrees C.
If it is a number thermostat, first check your box temp., then change the dial 1 number and check temp. in about 2-3 hours and see which direction it goes. Usually thermostats with numbers causes the temp to change very slowly so take your time and you can figure it out.
It is most likely a worn out relay tthey when it's could metal contacts in relay are not making connections I know it sounds weird but metal changes major in different temps
Perhaps your gauge is faulty. Is your coolant filled up? You may also have a vapour lock causing the problem. Also you may have to change your thermostat. It may be sticking. Good luck!
thereshould be some buttons groupped together on thedash gas mileage is mph/kilo air temp cel /fer push the button until u find the readings readable foryou
