If it's a cold humidifier, when was the last time you changed the wick? Some people think it's a filter, but it's actually a wick that picks up water from the reservoir and which the fan blows through, distributing moisture, ergo raising the humidity.
If it's a hot humidifier, when was the last time you cleaned it?
Either with a cleaner specified by the manufacturer, or with white vinegar which should dissolve any minerals built up from using tap water
For both types, using only distilled water instead of tap water will make the wick last longer in cold types and prevent mineral buildup around the heating contact surface in steam types.
Are you seating it right after fill ck the micro switch , may be misaligned
