Brand new, trying to hook a city water connection, had small ports blocked
If this is installed in a small rv , wow I know all about the problem with these , seems this type of pump allows one to draw water from a storage tank on board and the user provides the "power" via moving the handle up/down to draw up the water , but then when in the park you can connect fresh park water to faucet and using the same handle in opposite direction pressurized water flows out of it , first thing , its in a rv !! if inside air temp is not maintained 24/7 365 between 35F and 210F it plastic its gonna crack (mine did) and I don't know about you but my rv is outta my mind in the off season so no temp is being maintained inside it , if this is what happened then just replace it , no glue will hold up to its use ! second parks water pressures vary so carry your own water pressure regulator and use it between park and your rv ! these things only handle about 40 psi and then they crack open , and last but not least invest in some food grade rv antifreeze this is great stuff to "put up" the rv for the off season run it thru everything that gets water into it saves you tons on replacing things in the spring time
