Hi, Just because it glows that does not mean it is not bad... The ignitor is not working right and is going bad.... have the repair man replace the ignitor, or DIY.... Check out this tip about your problem...
This most likely is the solution for the bake problem you have: Find the bake ignitor (you may need to remove bottom drawer or oven
cavity floor to get to the ignitor). Turn on the bake. If the bake
ignitor comes on (starts glowing after a few seconds) - check the
amperage on
the bake ignitor wires when it's on. If the ignitor is a round style -
amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If
less
than 2.5A or 3A respectively - replace ignitor. If the ignitor does not
come on - check the voltage on the ignitor, should be the line voltage
110-120v AC. If there is a line voltage on the ignitor and it's not
coming on - replace.
Ignitor part numbers for round style ones: 4342528,
WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020,
5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if
you can splice the wires.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
