Standard Ignition Knock Detonation Sensor Ks140 Mazda Logo
d
debbie curry Posted on Mar 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What would cause a knock sensor to malfunction in a 2000 Pontiac montana sv6
It was running fine past the safety then all of a sudden wouldn't start sensor was fine when safety was done
drvalentine
Level 3:
Master:
  • Master 876 Answers
  • Posted on Mar 20, 2015
drvalentine
Master
Level 3:
Master:
Answers
876
Questions
0
Helped
255253
Points
4299
I have no idea what you mean by 'running fine past the safety' - but, sensors go bad, which is why they sell replacements. Chalk it up to coincidence and go on (have it repaired or replace yourself).
2answers
Diagram 2006 Pontiac montana
copy and paste https://www.repairprocedures.com/service-manual/document/2005/pontiac/montana-sv6-awd/engine/drive-belt-replacement/2829_866_18767_142376_12_1506919.html
What code p0332 is for my 05 pontiac montana sv6 3.5 engine??
That is for the knock sensor, bank 2. With transverse engine, the front bank on your vehicle should be bank two. You have more than one knock sensor, one for each bank.
2000 Pontiac Montana that starts and runs fine for 7-12 min then looses throttle power. Sputters at 1k-2k for 10-15 min then runs fine for 7-15 min then runs even worse, wills sputter at 750+ rpm.
3.4L Engine Sensor Location Pictures and Comments
www.greatautohelp.com/sensor-location/3400-Sensor-Comments-2.html
the battery for a few minutes to see if that helped. ... If the gauge is at half way on the first start, then yes, either the ... All of a sudden I could not accelerate and the carelost power. ... But once the temperature gauge goes to normal it will run fine. ... 3-7-12. I replaced head gaskets and intake gaskets on my 2000 Pontiac 3.4L
[PDF]2000 Pontiac Montana Owners Manual - GM Extended ...
2006 Pontiac Montana delayed transmission shift
my best answer would be is to check the condition of its fluid it might need a fluid and FILTER change .
Air flow intake sensor location
It may but there are other sensors that will affect the idle performance.. Run fault codes first. Check the condition of the PCV valve and the EGR valve.
2005 PONTIAC MONTANA FUSE BOX DIAGRAM
On this website you find fuse box diagram for Pontiac Montana SV6 2005 - 2006
Pontiac Montana SV6 2005 2006 fuse box diagram Auto Genius
3helpful
Service ABS and traction control systems is displayed in my 2005 pontiac montana sv6. New breaks have been installed and lights and system still on. Scanned and shows no sign of sensor issues
well this is a sensor problem. just cause you didnt get a fault code dome mean that the sensors are ok. Remove the abs Fuse from the fuse box under the hood. Drive the car and get a feel for the braking. Replace the fuse and drive again, you will notice one or more of the wheels dont hold as it fast or faster than the rest. Replace that sensor.
1helpful
2answers
Rear suspension left side makes a knocking sound while driving
There are a few suspension parts that can cause knocking noises. Such as swar bar loose, strut mounts going bad. You should really have a shop do a complete suspension check.
2answers
Have a pontiac montana, but lately when I press ths remote start button, the alarm goes off. Door locks work fine.
If its an aftermaket installation, do yourself a favor and have it removed. I have seen them disable a vehicle where they won't start. Sound like the controller is malfunctioning.
Top Standard Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Standard Air Tool and Compressor Expert? Answer questions, earn points and help others
