Computers & Internet Logo
A
Anonymous Posted on Mar 06, 2015
My Gateway PC is equipped with Bluetooth, how do I enable it?
  • stephen Adams Mar 07, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Which computer model?
risendshine
Level 3:
Master:
  • Master 178 Answers
  • Posted on Mar 07, 2015
risendshine
Master
Level 3:
Master:
Answers
178
Questions
Helped
30467
Points
3262
Hello there, make sure you have installed all the required drivers for the device. Please specify your PC model no. and the OS you are using.
How do I enable bluetooth on my gateway NE56R10U laptop?
It doesn't have built in bluetooth. Buy an external USB dongle.
Tiene bluetooth la gateway 6307
You will find out if you try the following. To turn the Bluetooth radio on: 1 Enable the Bluetooth radio by sliding the wireless network switch to the ON position. If the Bluetooth radio does not turn on automatically, press FN + F6.
Como activo el bluetooth de la gateway 6307
Juan Manuel,
I have to apologize that I can only post this in English. I was able to understand your question though.
You want to know how to turn on the Bluetooth Features of your Gateway 6307.
Try the instructions below:
1. Enable Bluetooth on the mobile phone or other Bluetooth enabled device. This procedure is dependent on the make and model of the phone or the device. You need to see the user manual accompanying your mobile phone or device to see how to enable Bluetooth.
2. Turn on your Gateway laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3. Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4. Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry 5. Select the Local Services tab. Startup type for all services should be set to "Auto."
6. Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
I hope this helps.
1helpful
I cant enable bluetooth on my pc
If it is an old laptop, it may not have come equipped with a Bluetooth device. You can buy an external Bluetooth transmitter which would plug into the USB port.
Gateway MC7801u Windows 7 Bluetooth
u can get the driver frrom he manufactures websites
How to activate bluetooth
How to Use the Bluetooth in the Gateway Laptop
ou may have bought a new Bluetooth-capable device like a Bluetooth mobile phone, and may want to load some ringtones or media files that you have stored on your Gateway laptop. This might be the first time you are ever attempting to communicate with a Bluetooth device using your laptop. Normally, Bluetooth has to be enabled on both the devices attempting to communicate. It is no good if Bluetooth is enabled on only one of the devices. All attempts at communicating via Bluetooth will fail. However, if Bluetooth is enabled on both the devices, bringing the two in close proximity is enough for the devices to detect each other. While this is what should happen and it happens most of the time, sometimes the devices need a helping hand. Here's where you come in.
Instructions
1Enable Bluetooth on the mobile phone. This procedure is dependent on the make and model of the mobile phone. You need to see the user manual accompanying your mobile phone to see how to enable Bluetooth.
2Turn on your Gateway Laptop. Check the area next to the clock in the System Tray. There should be an icon with a stylized "B" on a blue background. This is the Bluetooth icon. Double-click on this icon and select "Enable."
3Go to Control Panel. Locate "Bluetooth Configuration" and double-click on it. A window should pop up.
4Select the Accessibility tab. Check the option "Let other Bluetooth devices discover this computer." A check mark should appear against this entry.
5Select the Local Services tab. Startup type for all services should be set to "Auto."Select "OK" and click. Wait for a few seconds. Your laptop should have Bluetooth enabled by now.
Tips & Warnings
If your laptop does not detect the mobile phone even now, turn off the phone and turn it on again while keeping it close to the laptop.
Pl explain where is the switch of Bluetooth in Gateway LT 23, and how to enable it, and how to copy the data of another laptop via bluetooth.
bluetooth is not designed for data copy first off the connection is rather slow compared to usb/firewire. the FN+BT key enables and disables
8helpful
2answers
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
