Cisco Catalyst 2960-48PST-L - Switch - 48 Ports (V09362) Category: Network Switches Logo
A
Anonymous Posted on Mar 06, 2015
Cisco catalyst 2960 series switches support stacking?
Are cisco catalyst 2960 series switches support stacWhat specific models support stacking? If it support stacking,do I need to increase the stacking module? Or there is a stack port on the device? king?
Terry Hair
Level 3:
  • Cisco Master 4,134 Answers
  • Posted on Mar 06, 2015
Terry Hair
Cisco Master
Level 3:
Answers
4134
Questions
Helped
1090260
Points
16804
Yes they do support stacking. Here is the info sheet.
Cisco Catalyst 2960 Series Switches Products Services
Testimonial: "Oh, thank you. 2960 -s and -x series can support, but need to configure stackable module."
1helpful
What are the notable differences between the Cisco Catalyst 2960-X and 2960-XR switches?
The Cisco Catalyst 2960-XR switch models have the following additional capabilities in addition to the features in the Cisco 2960-X models:
Dual-FRU power supply with integrated fan
Layer 3 features with IP Lite feature set
Configurable 8 queues per port (standalone)
48 Ether channel groups
http://www.3anetwork.com/search/2960x
What is the difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL?
The main difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL as below:
WS-C2960X-24TS-L 4 SFP Uplink, WS-C2960X-24TS-LL 2 SFP Uplink.
WS-C2960X-24TS-L supports FlexStack-Plus stacking while WS-C2960X-24TS-L does not.
WS-C2960X-24TS-L with LAN Base feature set, WS-C2960X-24TS-LL with Lan Lite feature set.
I hope it can help you.
WS C2960X 24TS
Do I need to buy a software license for WS-C2960S-48FPS-L?
No. WS C2960S 48FPS uses the Universal image, but no license is required. The feature is bound to the hardware model type and cannot be changed. For convenience, a single software image is used for all Cisco Catalyst 2960-S Series Switches, regardless of whether they are a LAN Base or LAN Lite model.
2answers
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
2answers
Cisco Catalyst 2960-S VS 2960-X Series Switches?
2960-X is manual configurable and 2960-S is smart dont need to configure.
I forgot a password and i cant access a catalyst 2960 24-port 10/10
You can only reset password this way:
1.
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
login
line con 0
password <new pass>
15. write memory
16. copy run start
HAVE 24 PORT CISCO CATALYST 2960 SERIES SI ,HOW TO PUT IT BACK TO FACTORY SETING SO I CAN USE ALL 24 PORTS WITHOUT MANAGE..???
Due to the length of the solution I have provided you with a link to the Cisco site on how to reset catalyst switches.
It is not a simple process and you need to read the instructions carefully.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Hi, what's a password on the router Cisco Catalyst 2960 default?
Try using username (none) pass public/private/secret or
cisco - cisco, ADMIN - changeme, pixadmin - pixadmin, root - attack, superuser - superuser as username - password. These are the defaults credintials for the Cisco routers.
Stelios.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
