Dishwashers Logo
j
jessica Posted on Mar 06, 2015
Maytag jetclean quiet plus fills but wont wash or drain.
My dishwasher will fill with water but that is all it will do. After a few min the lights start blinking. Then I tried to drain it and it just clicks a few times but does nothing. I used a cup to get some water out and tried to wash again. Did the same thing, filled then stopped.
tml61747
Level 1:
  • Contributor 46 Answers
  • Posted on Mar 08, 2015
tml61747
Contributor
Level 1:
Answers
46
Questions
Helped
17389
Points
96
The mother board is going out, or the drain pump is failing. Try un plugging it...... by which i mean turning the power off to the unit and doing a soft reset. See if it recycles into the normal mode and works.
My MDB5600AWW isn't cleaning the dishes. Even easy stuff like wet pasta sauce. I watched/listened and discovered the water is not staying in the tub during wash cycles. It fills, then slowly (1-2 mins)...
Check the drain hose... it sounds like it has fallen down too low and is not looped high enough to keep the water in the tub....this will let the water drain right out as it fills like you are saying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
2answers
Maytag dishhwasher turns on but no water is going in to wash dishes and the heating element is on
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Quiet Series 200: The water is not draining out.
6 to 7 years is about right without put out major repair costs. Unfortunately salesmanship is the biggest racket going. I'd scrap it or sell it for parts. Sorry
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
7helpful
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Maytag MDB7600 issues
reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Mdb 6600aww
i need your serial num its important
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
