On this kind of cameras its impossible. U need a tracking adjusting button which is only on pro cameras. I doubt if its worth to give it in for repairs
Sony camcorders has no tracking control for user. I think video head is dirty / clogged. Put good quality video head cleaning tape in camcorder and check. Its almost 15 years old camcorder.
the first thing i would do would be to try a head cleaning tape-if that doesn't help see in your book or menus if you can adjust the tracking on the camcorder-when the tape heads get worn over time they need to be aligned and that is what tracking does-some older models allow you to manually adjust-good luck!
I have had the same problem. There is no way to manually adjust the tracking on this Hitachi, or on most 8mm cameras, for that matter. I copied all of my more recent tapes to DVD first (2 copies of each) and then I went to the oldest tapes, which for some reason were OK. When I got to one tape that gave me trouble, I just let it play in the camcorder for about an hour. It adjusted its own tracking so that the picture was OK. Then, I rewound the tape and copied that one. I still have 2 tapes that will not adjust. I am going to send those out to a copying service. I hope they can adjust the tracking and make the copies I need.
By the way, I used this camera and a Panasonic DMR-E55 to make the DVD copies.
It's not tracking -- it's dirty heads -- you can purchase an 8mm head cleaning cassette and use it to cure these problems. Tapes recorded with the dirty heads may still have issues afterwards.
hi
i think u r from india i am from india too
first of all put a new cassete in that camera
and play your head cleaning cassete in that camera
so that your problem is solved otherwise you have to change your camera video head or have to adjust your camera,s deck portion
bye
aman
[email protected]
First, try head cleaning by trained technician. Tech will clean manually with cleaning chemical each head to make sure video heads are performing 100%. Otherwise, they will probably quotes you for tracking adjustment. Head cleaning is typically around $25-50. Tracking adjustment might cost you around $100-200 in US depending on service time.
