Exercise & Fitness Logo
A
Anonymous Posted on Mar 06, 2015
NordicTrack C900 Pro Won't turn on
My wife and I purchased a C900 Pro used. It was working fine when we picked it up. We disassembled the unit to move it into an upstairs room. Now, after reassembly, the unit will not turn on. Everything is hooked up correctly, and no wires are pinched.
Mike Tellegen
Level 3:
  • Master 1,631 Answers
  • Posted on Mar 06, 2015
Mike Tellegen
Master
Level 3:
Answers
1631
Questions
Helped
1013194
Points
5840
Double check:
Chances are that "$%#T Happens" is not your problem. And that if it worked prior to "dis-assembly, it should work after re-assembly". The common denominator is you took it apart & put it back together. So.. something was missed. A wire not connected, a switch not flipped, a wire in the wrong spot, the safety key not in the slot, etc, etc.
Good Luck
1helpful
Why is NordicTrack C900 belt lifted at the edges? How to flatten belt edges even if it's already properly tightened, centered, and lubed?
Question edited for clarity and typos.
Question moved from Televisions Category, to make model.
It is either that the belt is too tight, or the belt is worn out. The rollers are slightly 'crowned' fatter in the centre than the edges. If the belt is too tight, it will pull the edges up, or it is has been run too long or too tight, the belt wears in the centre, so being thinner in the centre, it curls. Time for a new belt.
Posting pictures is easy. :>D
NordicTrack A2550 Pro Treadmill. It was sitting in another room and started without the safety key in it.
Apparently the key is magnetic, so perhaps you had a magnetic event? Having said that, it shouldn't run unless switched on. Better to turn off at the mains when not in use.
https://www.google.com/search?q=nordictrack+a2550+pro+started+without+key
Wont connect to internet
If you're seeing the WiFi but cant connect to it try using a different type of security like WEP OR WPA.
If you cant see the WiFi at all try to use a range extender. The treadmill might be too far away from the router.
Manual pdf
pleaso go to http://support.nordictrack.com/
and download PDF.
God bless you
My New Nordictrack c900 pro turns on but does not run.
You probably pinched some wiring during assembly. Could be the controller but more likely the wiring.
Error 100 won't connect to network anymore to use ifit live
Check the power cord to ensure it is connected to the power supply and the treadmill if the power does not stay on or does not turn on. Look at the circuit breaker, located near the base of the unit, to see if the circuit was tripped. Push the switch back in to reset the circuit.
  • 2 Take the key out of the console, wait a minute and place it back in the console to resolve issues with the power turning on and off during use or if the console displays are not functioning properly.
  • 3 Remove the console key and press the "Stop" button to turn off the "Demo" mode, which is often the default setting when the treadmill is first purchased.
  • 4 Reset the incline by holding down the "Stop" and "Speed increase" buttons and putting in the console key. Release the buttons and then press the "Stop" button, followed by the down or up arrows for the incline. This step can be taken if errors are occurring with the incline function.
  • 5 Turn the treadmill "Off" and unplug the unit if errors continue. Wait five minutes and then plug the unit back on, insert the console key, and turn the treadmill "On." This will reset the treadmill and should return to normal funcTION
  • Not finding what you are looking for?
    Top NordicTrack Exercise & Fitness Experts
    NOEL
    NOEL
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
