Sewing Machines Logo
A
Anonymous Posted on Mar 05, 2015
Where can I buy a Viking 6020 sewing machine cam gear
Bill Dickerson
Level 3:
  • Master 979 Answers
  • Posted on Mar 05, 2015
Bill Dickerson
Master
Level 3:
Answers
979
Questions
0
Helped
309480
Points
2196
EBay, has just about everything. Chances are the price will be good since there is not a high demand for these items.
gbob59
Level 3:
  • Husqvarna Master 3,063 Answers
gbob59
Husqvarna Master
Level 3:
Answers
3063
Questions
Helped
705907
Points
10419
Dealer, possibly Ebay, possibily sewing materials store can order for you.
Will attachments - Cams, feet and bobbins - for a 6020 Viking be compatible with a 70's 6460 model?
Most likely Not. Do a search for accessories for both machines and see which ones come up as compatible. Or, just contact a Viking dealer.
The plastic gear in the 6010 Viking is cracked and I'd like to replace it.
Have you searched the internet?
Absolute Sewing Machine Information Husqvarna Viking Service manual
Sewing Machine Viking 6000 Cam Replacement (not sure if it is the cam gear that needs replacement)
If you are unable to find instructions, perhaps you can find an independent sewing machine repair person who would be willing to do it for you.
Power won't stop Husqvarna/Viking 6020 sewing machine
grant514 Has pretty much hit the nail on the head but the RF suppressor is located in the motor housing, not the foot pedal. It bridged the terminals where the foot pedal connects. Removing this capacitor resolved the same issue in my machine and given the absence of radio receiving equipment in my home now I have had no ill effects.
I have a Viking sewing machine from the 70's. The cams aren't working correctly. I've had plastic parts and a metal ring replaced by a certified Viking repair person, but still not working correctly. ...
Was the inner zig zag gear replaced? To check this, look in the hole where the cams go. You should see the black plastic gear with 3 slots all the way around where the your cams lock on to. Look at the gear closely. You should NOT see any crack or splits in the plactic gear. If you do, then this why your go on properly.
2helpful
3answers
Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
3helpful
The needle in my Viking 6440 is locked in on the left side and the machine will only sew in reverse. The reverse button cannot be moved in or out.
I'm trying to find a machine similar to yours and have done much research re: the older mech viking sewing machines 6000 series. They are GREAT machines, suffering only from problems such as yours caused by the old "lube/grease" they used when it was made @ factory. In their efforts of making a "never needs oil" mech sewing machine, the grease tends to harden & freeze up the gears & cams inside the machine. You need to have it serviced @ authorized Viking shop as you have to completely disassemble the machines & gears, clean, re-lube, & re calibrate the gears... I understand this s/b ~ $175. Money well spent considering if taken care of your beauty could be sewing for another 60 yrs!
Hope this helps!
2answers
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Need to buy spare part: Thread take up lever for Husqvarna Viking Model 6020. Traveled on airplane and inspectors broke my machine!
start trying viking dealers or ebay this machine is no longer supported by viking and is NLA on all parts so your best bet is a dealer that might have a junk one for scrap parts
21helpful
5answers
Husqvarna Viking Sewing Machine 6020 sews in reverse
It doesn't need a part for this repair. The reverse mechanism inside the machine is seized from old grease which has hardened. It should be seen by a technician so the part can be cleaned out. Don't be surprised if he finds a broken take up slide or a cracked pattern mechanism.
Get an estimate before you have any work done and ask about a warranty for the work they plan to do.It may be less expensive to buy a newer machine.
sewman7
Users manual
You can download a manuel for $7.95 from www.gomanuals.com
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
