Connected it to my laptop VIA HMDI and all of a sudden a green/blue horizontal line appears through the TV from one side to the other. Tried turning it on and off/resetting and unplugging none have yet worked.
Could be your display panel. check all your connections between the T-con & display panel, look specifically for corroded contacts at the panel plug, if you have that, try to clean those contacts.
If that doesn't cure it you may need the display panel. This would not be cost effective unless you found a used unit with a known good panel & could purchase very inexpensively.
