How complicated is it to fix the control panel on a Kenmore self cleaning oven with ceramic top stove? It was bought in 2003 and I'm not sure of the model# I'm trying to decide if it is something I should try or if I should let the Sears experts handle it. I am not an overly skilled handy woman but I can manage small repairs with instruction.
SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
SOURCE: Kenmore oven locked after celf cleaning
I had the same problem today. After I cleaned my self cleaning oven the cycle went back to normal but the oven door would not open even though the screen was clear and didn't read locked. I held the stop button for 3 second, I don't remember what the message said on the screen but I held the stop button in again for 3 seconds and the screen said locked then I did it again and the screen said door and the oven opened. I don't know, maybe it was just sheer luck it's worth a try. I'm happy.
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
SOURCE: self cleaning oven directions
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
