Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The control display lights flash, and the
The control display lights flash rapidly, and the refrigerator doesn't work. It won't turn off or respond at all.Water filter replace light also flashes, but again it won't reset, or allow temp adjustments. Tried to unplug to rest but no change.
Anonymous
Level 2:
  • Expert 523 Answers
  • Posted on Jul 09, 2009
Anonymous
Expert
Level 2:
Answers
523
Questions
Helped
134482
Points
944
Sounds like demo mode
1helpful
2answers
Whirlpool quiet partners II normal light flashing
CHECKING KEYPAD OPERATION
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Lights and pump turning on and off rapidly in succession
I had this, there are two circuit boards, one on the front under the switches the second in the back near the compressor. which is really hard to reach, your guessed it, its the one near the compressor that needs replacing, its around 70 pounds stirling..
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
1helpful
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 • Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
I have a 2004 Silverado 1500. The rear lights won't turn off, pulled all the fuses associated with lights and they still don't turn off. In addition my right turn signal doesn't flash, both the...
Not sure, but I've heard a bad hazard switch can cause strange problems.
Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
I have a new Samsung side-by-side refrigerator (model # RS265TDRS) that I am using for the first time. I plugged it in today, and the control panel display has been flashing "23 E" all day (NO...
Push and hold power freeze and power cool simultaneously until display flashes. Release and leave alone. You just reset the brain on your display. In an hour or so, reset the desired freezer and refrigerator temps. My suggestion, -6 on freezer, 44 on refrigerator.
3helpful
The Control Panel/Dispenser light went crazy...
Sounds like a electronics problem would need to replace the board, LG parts are not normally expensive.
Dishwasher does not start
I have the same problem. I've tried everything;even took apart the control panel and checked for corosion. I ended up changing the control board-$130 down the drain- The only other thing I can figure is the button panel has some sort of short- also ~$130-. good luck. Now I use the sink (wife's not happy) Tech sheet is behind kick plate.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
