It's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
SOURCE: Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Please rate my solution.
Thanks.
SOURCE: Hotpoint WMA76 - been on a normal wash cycle but
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
SOURCE: My Hotpoint Ultima WF860 will
the belt has come off or broken on the back take lid or back panel off and have a look
SOURCE: I cancelled the rinse cycle before it was finished
Hi If the door lock assembly is fine then the issue is with the
control board that is bad and should be replaced. Hope this helps...please post
back for further assistance. Daniel
