Won't go into the final spin cycle and overflows
For Dinkysouth:
Apparently your machine is getting power to the water valves when it should be draining and then going into Spin. Also, since it keeps filling to the point where it overflows there must be a constant signal from the electronic board that bypasses the water level pressure switch. If you can, you should go into the Service Program and check the individual items. Most likely, you will end up needing a new board.
