Question about Mercedes C-Class Exterior Pillar Posts Trim Set
How do you check the transmission fluid on this car?
    Sergeant:
  • 210 Answers
Posted on Mar 05, 2015
SOURCE:
How to check tranny fluid in a 2000 lincoln ls
Transmission Fluid Level Check Lincoln LS (2000-2006)
Our research indicates that your vehicle does not have a transmission fluid dipstick. These types of transmissions are designed to be maintenance free. In order to check the transmission fluid, your vehicle likely has check valve on the bottom of the transmission on the bottom of your car. Your car must be level when the fluid is checked and we therefore recommend having a mechanic with a hydraulic lift or underground bay check your transmission fluid. Any fluid leaks for this type of transmission should be treated by a mechanic.
Sep 22, 2018 | Lincoln Cars & Trucks
Transmission hard shift
follow this troubleshooting section for oil transmission.
n automatic transmission depends on the transmission fluid for transferring engine power to the wheels, shifting gears, lubricating moving parts and cooling down the transmission. Check the transmission fluid when your car is serviced and change it as recommended. Different cars have different ways of checking the transmission fluid level; some require the engine to be shut off (e.g. Honda), some cars don't have a transmission dipstick at all and the fluid can only be checked in a repair shop. Check your owner's manual for proper procedure. This is how the transmission fluid checked on most cars: transmission-fluid1.jpg After the vehicle was driven for a while to let the transmission fluid warm up, place your vehicle on a level ground. Set the parking brake. Make sure the transmission is in "P" (Park) position. Leave the engine running. Find the automatic transmission dipstick (your owner's manual will tell you where it is located). Pull the dipstick out.
transmission-fluid2.jpg Wipe the dipstick off with a clean lint-free rag. Insert it back fully. Pull it out again and check the fluid level. A transmission fluid expands when warmed up, so if the car has been driven for a while (20-30 minutes), the transmission level should be between "HOT" marks. If the vehicle is cold, the level should be between "COOL" marks. Check the fluid condition: a very dirty fluid with strong burnt smell is a warning sign of transmission problems. Normally the automatic transmission fluid should be clean and transparent, as in these photos.
transmission-fluid3.jpg On most cars the new transmission fluid comes red (photo on the left). Over the time it becomes brownish, as in the photo below.
transmission-fluid5.jpg This is how the synthetic transmission fluid looks after two years of driving - it's still clean and transparent. If your fluid looks very dark or dirty, check your owner's manual, maybe it's time to change it. Some manufacturers require to change the transmission fluid at 30,000 or 50,000 miles others specify that you never have to change it - check what's your car owner's manual says.
transmission-fluid4.jpg If the transmission fluid level is low, you can top it up, but be careful not to overfill it. Overfilling the transmission can cause problems. It's very important to use only specified transmission fluid type - check your owners manual or simply visit your local dealer, they always have proper transmission fluid in stock. Incorrect fluid type can damage your transmission. How to top up the transmission fluid: Using a thin funnel, add a small amount of the fluid through the dipstick pipe. Wait for a few minutes - let the fluid drain down. Recheck the level again. Don't overfill
Sep 30, 2013 | 2001 Hyundai XG300
The automatic transmission is shifting oddly and speedometer jumps back and forth. The problem seems to occur when shifting into and out of 2nd gear. It seems like it has a hard time selecting the gear...
please this chart troubleshooting and fix it. God bless you
How to check automatic transmission fluid. An automatic transmission depends on the transmission fluid for transferring engine power to the wheels, shifting gears, lubricating moving parts and cooling down the transmission. Check the transmission fluid when your car is serviced and change it as recommended. Different cars have different ways of checking the transmission fluid level; some require the engine to be shut off (e.g. Honda), some cars don't have a transmission dipstick at all and the fluid can only be checked in a repair shop. Check your owner's manual for proper procedure. This is how the transmission fluid checked on most cars:
Sep 30, 2013 | 2001 Chevrolet Cavalier
Transmission shifts hard
see the chart troubleshooting and proceed according. God bless you
Sep 30, 2013 | Hyundai XG300 Cars & Trucks
Transmission sensor
follow this steps and fix it. God bless you
First, check the transmission fluid level and condition. If you don't know how to do it, here is an illustration:
How to check the automatic fluid
With the engine idling and transmission in "Park" (some car may have different procedure, refer to the owner's manual) remove the automatic transmission dipstick and wipe it out with the clean lint-free cloth. Insert the dipstick back fully and then pull it out again. Check the fluid level; low level may indicate a transmission leak. Look at the fluid very closely. It helps if you drip the fluid onto a white paper to be able to see the fluid condition. The transmission fluid should be clean and transparent, without any metal filings or black flakes. The new fluid usually comes red. Over the time, it become more brownish, but it shouldn't be very dirty or black. Look at the image. Try to smell the transmission fluid; It should not have a burnt smell.
All this may seem difficult, but when you check few similar cars, you'll be able to see the difference. If the transmission fluid is too dirty or black, or smells burnt, it's better to avoid such a car.
Keep in mind, however, that some modern cars don't have the transmission dipstick and require special procedure performed in the auto repair shop to check the fluid level. In this case, the only way to check the transmission is on test drive. cc037824-574e-464e-b4e8-ab64c6eee062.jpg
Jul 23, 2013 | Toyota Sienna Cars & Trucks
How do i drain transmission fluid and replace trans-filter 1996 chevy suburban 4x4 454
Finding where to put transmission fluid can be a bit of a challenge on some cars. In fact there are some transmissions that you can't even add fluid to.But that's not the case on your vehicle.
First confirm the level of fluid before filling it.==========For exact transmission fluid replacing/filling procedure.Go through the list of help links below:-----its having complete step by step procedure.Click the link :----
HOW TO CHECK AUTOMATIC TRANSMISSION FLUID LEVEL
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
HOW TO CHANGE AUTOMATIC TRANSMISSION FLUID AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
HOW TO REPLACE A TRANSMISSION MOUNT
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-transmission-mount.html
How do you change transmission fluid on Pontiac?
http://schematicsdiagram.blogspot.in/2012/03/how-do-you-change-transmission-fluid-on.html
Filling Transmission fluid on 2001 Volvo c70?
http://schematicsdiagram.blogspot.in/2012/02/filling-transmission-fluid-on-2001.html
2002 Isuzu trooper Transmission fluid fill up?
http://schematicsdiagram.blogspot.in/2012/02/2002-izusu-trooper-transmission-fluid.html
AUDI V8 TRANSMISSION FLUID
http://whoisbyme.blogspot.in/2012/07/audi-v8-transmission-fluid.html
Where to fill Transmission Fluid on 2001 ford focus
http://technoanswers.blogspot.com/2012/10/where-to-fill-transmission-fluid-on.html
Transmission fluid gets into radiator?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fluid-gets-into-radiator.html
How to check Transmission fluid on 1996 Chevrolet Camaro?
http://schematicsdiagram.blogspot.com/2011/12/how-to-check-transmission-fluid-on-1996.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Filled T-IV fluid instead of WS transmission fluid?
http://repairhelpcenter.blogspot.com/2012/01/filled-t-iv-fluid-instead-of-ws.html
How to Add transmission fluid on 2002 Isuzu AXIOM?
http://technoanswers.blogspot.in/2012/02/how-to-add-transmission-fluid-on-2002.html
2003 Toyota Prado Diesel Engine: Transmission Fluid Refill?
http://whatisbyme.blogspot.in/2012/05/2003-toyota-prado-diesel-engine.html
-------------These details will help.Thanks.
Nov 27, 2012 | 1996 Chevrolet Suburban
Add fluid transmission
TRANSMISSION FLUID
Checking automatic transmission fluid
The 5R55N transmission does not have a transmission fluid dipstick.
Refer to your scheduled maintenance guide for scheduled intervals for
fluid checks and changes. Your transmission does not consume fluid.
However, the fluid level should be checked if the transmission is not
working properly, i.e., if the transmission slips or shifts slowly or if you
notice some sign of fluid leakage.
Transmission fluid should be checked and, if required, fluid
should be added by a qualified technician.
Aug 23, 2012 | 2001 Lincoln LS V8
I cant check fluid in transmission no dipstick
THE 4T40 E 4T45 E AND 4T65 E THESE TRANSMISSIONS DONT HAVE A FILL TUBE WITH DIP STICK.THOSE TRANSMISSION VECHICLE HAS TO BE PUT ON A LIFT AND LEVEL. TRANSMISSION HAS A FLUID CHECK PLUG LOWER HOUSING TRANSMISSION JUST ABOVE THE OIL DRAIN PLUG.TO CHECK FLUID TRANSMISSION NEED TO BE OPERATING TEMPERATURE. WITH ENGINE RUNNING AND TRANSMISSION FLUID PLUG REMOVE IF TRANSMISSION FLUID POURS OUT. CHECK PLUG HOLE.YOU HAVE TOO MUCH TRANSMISSION FLUID IN TRANSMISSION.IF FLUID DONT DRIP OUT HOLE NEED TO ADD A PINT AT A TIME.IF FLUID DRIPS OUT SLOWLY FLUID CORRECT TO POUR TRANSMISSION IN TRANSMISSION RAISE HOOD LOOK ON TOP TRANSMISSION ON DRIVER SIDE FOR A RED VENT FILL PLUG.REMOVE PLUG USING A LONG LONG FUNNEL POUR TRANSMISSION FLUID IN THE VENT FILL PLUG HOLE.THIS VECHICLE THE DEALERSHIP HAS TO CHECK FLUID USING A LIFT.YOU CAN DO THIS JOB BUT IT WILL VERY DANGEROUS YOU CAN PUT CAR ON JACK STANDS WITH VECHICLE SITTING LEVEL. BUT THE DANGER PART COMES YOU HAVE TO SLIDE UNDER THE CAR WHILE ENGINE RUNNING TO CHECK FLUID.IF YOU DO THIS JOB HAVE FRIEND OR HELPER AROUND DONT WORK UNDER CAR BY YOUR SELF ALWAYS KEEP CELLUAR PHONE ON HAND FOR EMERGENCY.
Aug 11, 2011 | Chevrolet Cavalier Cars & Trucks
I cannot find the transmission dipstick
TRANSMISSION DONT HAVE DIP STICK,YOU HAVE A CHECK PLUG LOCATED UNDER TRANSMISSION NEAR THE PAN ADJACENT TO THE ENGINE OIL DRAIN PLUG.CHECK PLUG IS A METRIC 11M OR 12M METRIC BOLT.TO CHECK FLUID CAR HAS TO BE LEVEL AND ENGINE RUNNING.WHEN YOU REMOVE CHECK PLUG, IF FLUID POUR OUT YOU HAVE TOO MUCH TRANSMISSION FLUID IN TRANSMISSION, IF FLUID SLOW DRIP YOU HAVE ENOUGH FLUID IN TRANSMISSION, IF NO FLUID DONT DRIP OUT WHEN CHECK PLUG REMOVED,ADD A PINT OF TRANSMISSION FLUID AT A TIME.YOU POUR FLUID AT TOP OF TRANSMISSION UNDER THE HOOD,YOU WILL SEE A RED VENT FILL CAP, REMOVE CAP, YOU NEED A VERY LONG FUNNEL TO POUR TRANSMISSION FLUID IN THE TRANSMISSION. IF YOU HAVE TRANSMISSION SHIFTING OR SLIPPING PROBLEMS,MOST TIME TRANSMISSION DUE FOR FILTER AND FLUID CHANGE IF YOU AT THE 60000 MILES TO 120000 MILES TIME FOR FLUID AND FILTER CHANGE.
Apr 08, 2011 | 2001 Pontiac Grand Am SE
How do you check the transmission fluid on the alero ? i can not find a dip stick
TRANSMISSION DONT HAVE A DIP STICK.IT HAS A RED FILLER CAP INSTEAD.TO CHECK TRANSMISSION FLUID THE CAR HAS TO PUT ON A LIFT LEVEL.TRANSMISSION HAS A CHECK PLUG.ITS UNDER THE EXTENSION HOUSING.THE OIL PAN DRAIN PLUG IS BELOW IT.YOU NEED A DRAIN PAN AND THE CAR NEED TO BE RUNNING AT OPERATING TEMPERATURE.WITH ENGINE RUNNING YOU REMOVE THE CHECK PLUG.IF NO FLUID DIPS OUT YOU NEED TO ADD SOME FLUID.IT FLUID POURS OUT YOU HAVE TOO MUCH TRANSMISSION FLUID IN SYSTEM.IF YOU GET A SLOW DRIP YOU HAVE THE CORRECT AMOUNT OF FLUID IN TRANSMISSION.THE CAR HAS TO BE LEVEL AND YOU PUT FLUID IN THE TOP OF TRANSMISSION WHERE THE RED VENT FILL CAP IS.YOU NEED A LONG LONG FUNNEL TO PUT FLUID IN WITH OUT SPILLING FLUID ALL OVER THE PLACE.
May 08, 2010 | 1999 Oldsmobile Alero
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
48 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
