Toshiba E-Studio 2830c Color Copier Copy/print/scan/fax Logo
A
Anonymous Posted on Mar 04, 2015
How do I repair a ca00 error - Toshiba E-Studio 2830c Color Copier Copy/print/scan/fax
didi2005
Level 3:
  • Toshiba Master 727 Answers
  • Posted on Mar 13, 2015
didi2005
Toshiba Master
Level 3:
Answers
727
Questions
Helped
428107
Points
1454
CA00 is a image problem.
It can be caused by insufficient of developer materials or main charger problem.
I hav error code caoo on toshiba estudio 2050c pls help
CA00 is machine cannot finish the calibration.
Most of the time is due to the cleaner unit toner harden, causing the spring come out and jammed on the transfer belt unit.
If not cleaner unit problem, u need to check which PU causing the error, probably the main charger hook broken.
3answers
Toshiba 5520c error ca00
the link I attached might help.
Good luck & have a nice day!
Thread Toshiba studio 3530c CA00 error code
How can I fix a CA00 error code?
Well, you don't specify what printer you have, but a Google search for that error code mainly comes up with Toshiba, so try this link, which has several suggestions:
There are also past discussions of that error in Fixya:
Questions Answers for toshiba ca00 error
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Toshiba E 6520C have problem CA00 I have probem
I agree this would be best to have a service technicians service this machine being if an attempt is made from first solution and doesn't solve the issue and a service technician does have to be called it may cost more.
Error code CA00 what is that
Communication error try rest in 08 - 690
4helpful
Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
14helpful
2answers
Toshiba eStudio 2500c - CA00
This is a pretty complicated issue/problem. there are 5 pages devoted to this issue in the service manual. This issue would be best handled by a technician. but you could try the following....
[CA00] Color registration abnormality
<Color toner low density>
Turn on the copier holding down 0 and 8 and wait till it boots up into its service mode..then enter code 2692 “Prevention of color toner low density / change the zero to 1.
Then change code 2693 “Prevention of color toner low density / Judged number of sheets setting” value to 40 (default 20).
Make sure you have cleaned the main charge units by fully extending the rods with the green handles for each color.(open the front door) and use the plastic wand attached to the front door to clean the laser glass for each color..there is a small **** under each color unit to slid the wand into..felt side down on the wand.
Like I said there are several other complicated ways of fixing this.
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
