The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Sounds like a problem with the bushing around the accessory drive. If still under guarantee take it back and get it sorted. If out of guarantee take it to an authorised service centre.
I just got the same problem too. There was a little piece of fat in the meat and it stopped the grinder. I removed it but the attachment rotates a full turn and then stops. The same happens with other attachments even under practically no load.
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
There are all kinds of Oster Kitchen Center parts and attachments for sale on Ebay. Here is another site that sells Regency parts: http://www.Goodman's.net
Can you help me with my Regency problem? I bought a used one with the hopes of using a lot of the attachments including a meat grinder (did not come with), but now after receiving the OKC there is no hole in the side of the mixer arm to attach the grinder - there is a metal circle. Do I need to punch out this circle - like an electrician does with an electrical box? HELP
This may be a problem with assembly of the Sausage Stuffer Attachment. Your Use and Care Guide for both the Food Grinder and Sausage Stuffer could illustrate the assembly for you in detail.
Also, it may take up to 4 minutes after meat is fed through the top of the Food Grinder for it to start stuff into the casings. The meat is fed into the Food Grinder, ground, and then pressure is built up behind this ground meat to push into casings.
