I do know how to pair my headset to the tv. I also bought the Samsung entertainment center thinking that would work. I can connect to the sound system but not to listen to the tv
SOURCE: Motorola H500 not able to connect to Vista
I had the same problem w my Compaq Presario V3000 HP BT module. I installed the HP Bluetooth drivers from hp.com and that fixed it. So instead of using Vista's built in stack, try one that your manufacturer may have issued.
Pim from the Computer People
Helping Kiwis go places
Ph. +64210398346
SOURCE: listening the FM Radio on laptop
like the guest said uptop there is no way do to it
sorry
~Temp
SOURCE: reset samaung headset wep200
It worked with my iphone also, i have WEP250. First u need to turn off bluetooth on the phone also, then turn off tooth, then push and hold till solid blue light comes up, then turn on blue tooth on the fone, it finds it in 2 sec, passcode 0000
SOURCE: how can i pair my samsung bluetooth headset to
turn off the head set then press and hold the on button until the blue light stays solid blue.
search for device on your new phone and add device code is 0000
Pairing the
Headset with a Sony Playstation3 Entertainment System:
To pair your [EM-227] Bluetooth Headset with the Sony
Playstation3 (PS3), go to the PS3 main menu, scroll to "Settings"
and select.
Scroll to "Accessory Settings" and select.
Scroll to "Manage
Bluetooth Devices" and select.
The menu will ask: "The Bluetooth device has not been
registered. Do you want to register it?"
Select YES.
Put your [EM-227] Bluetooth Headset into discover mode (see
X.XX of this manual for instructions on how to get the headset into discover
mode).
Select "Start
Scanning" from the PS3 menu.
Once the PS3 has discovered the [EM-227] Headset the screen
will read "Select the Bluetooth device
to register".
Select [EM-227].
The PS3 will ask for a passkey. Enter [0000] then press "OK".
Now press O (the PS3
circle button) to get back to the previous menu.
Scroll to "Audio
Device Settings".
Change the "Input
Device" to [EM-227].
Note: "Input Device" is the
microphone, how others will hear you speak.
By default, the "Output
Device" will now switch to [EM-227].
Note: "Output Device" is the
audio, how you will hear the PS3 audio and others speaking.
If you would like to hear the PS3 audio and others speaking
through your TV or Audio System, scroll to "Output Device" and switch to "System
Default Device". If you would like
to hear sound through the [EM-227] headset, then leave the "Output Device" setting on [EM-227].
To test your connection, speak into the headset and you will
see the bars above the "Microphone Level"
moving. If not, repeat the pairing
process.
Press "OK" to
confirm the new settings. You are now ready to use the [EM-227] Bluetooth
Headset with your PS3 Entertainment System.
For further assistance with Bluetooth settings on your PS3 please refer to your PS3 instruction manual.
