Ok.. I'm assuming you have a relatively new NRV system with POE cameras. You can see the video on your smart device you must have the IP addresses correct in your NVR system. Connect from the NVR box to my TV using an HDMI cord. HDMI cord is one cord that attaches to the back of the NVR box where it says HDMI out and it goes to the back of the TV show where it says HDMI in. And then you must go to your TV menu and select HDMI input option. Sure hope this helps
Most new TV's are coming out with only HDMI inputs. If your TV has only HDMI, and a (cable) in, Then there are 2 ways to connect your PS2. 1) Buy a rca(audio/video) to HDMI converter. These are available on Ebay in several different designs.2) Buy a PS2 cable ready coaxial converter available from Ebay, or your local gamestop store. Remember, the cords for the PS2 and the PS3 are EXACTLY the same.
If your TV has no HDMI input to connect with your laptop's HDMI output, surely you need a converter. If the laptop have A/V output, and the TV too have an A/V input, you can connect in between, using an AV cord. google.com/+GopakumarGopalan
there is a converter box , where you can connect everything and convert in to hdmi output , you can buy this boxes on the internet or at the redioshack
1. If your TV will accept a high definition signal from the PC you can connect the PC to the TV with an HDMI adapter. 2. HDMI just allows sound and video to be transferred and to be sync'd with the device connected.
There are adaptors available to convert HDMI signal to other standards. You will lose quality in picture and sound but you can get HDMI to RCA converter. If your TV has a DVI is still a digital input so will yield better quality.
If you tv has a hdmi input, connect it to the Yahama receiver hdmi output (out). If you are using a satellite receiver, digital converter, or a cable box with hdmi output(s), connect them to the Yahama hdmi input (in) for video and audio signals. If the above box(es) do not have hdmi capabilities, then connect the box(es) to the Yahama with either component (preferred), svideo, or yellow RCA compsite video jack (least preferred) for the video signal. For audio, connect the box(es) with optical or coax (preferred) or left-right-center-front-rear patch cords.
It really all depends on what outputs are available on the boxes and/or signal source(s).
